Hedman Hussler headers sbc stahl pattern
Car: 91' camaro rs
Engine: Sbc 327
Axle/Gears: Stock 10 bolt w/posi 3.90 gears
These headers are stepped 17/8”-2” for third gen f body. Hedman hustler. They will not fit standard sbc heads, they for stahl pattern heads but you can get adapters To work with standard sbc heads pretty cheap online. $250.00 plus shipping. I’d trade for LS swap stuff like engine mounts, turbo headers, turbo, turbo setup things, ls6 or Ls2 intake or comparable, working 90-92 145 mph cluster, spohn torque arm crossmember mount(already have the crossmember), nice high performance ls clutch,Ls sfi flywheel, Intercooler that fits our cars, ls turbo cam, let me know what you have otherwise cash is king. Thanks!
Car: 85 IROC,
Engine: 5.7 Crate Motor
Re: Hedman Hussler headers sbc stahl pattern
Hi, will these work with a standard trans? Clearing the slave cyl is a concern.
thanks!
thanks!
Car: 91' camaro rs
Engine: Sbc 327
Hi, I’m not positive if these will clear the slave as I’ve never had these in my car. I bought them intending on using them but decided to go the LS route. I honestly don’t think many if not any long tubes fit these cars with manual trans without modifications. I think edelbrock used to make a set that cleared. Thanks.
Engine: LB9 305
Transmission: AT
Jeeeze! I remember Hedman Husler Hedders from when I was a teenager!
Car: 85 IROC,
thanks again
Car: 91' camaro rs
Engine: Sbc 327
No problem. Yes they are slip fit. These headers are bad *** looking and can support a lot of power. I like how they have flat collectors , I would think they would allow extra clearance to the road. It would be worth doing some mods for the price. I haven’t priced these new in a while but I think they’re in the $850-$1000 range. It’s too bad I can’t use them but someone who can should buy them instead of them sitting in my garage as ornaments haha! Give it some thought. Thanks!
Z28ricer
03-18-2002 12:46 PM
