[IL] TPI stuff, L98 cam
Car: 1986 IROC-Z
Engine: 5.7 TPI, 113 heads, Comp Cam
Transmission: 700R4, 2500 stall
Axle/Gears: 3.42 Posi
TPI stuff, L98 cam
Update 7/1/23
need this stuff out of the garage going to scrap soon if nobody wants it
small cap distributor. From a 92 with 32k miles. Has a parts store ignition module in it tho.
runners and base, early style with 7th injector
adjustable fuel pressure regulator. Not sure of the brand
egr valve
plennum extension/distributor cover. Plastic one.
egr valve
![](https://cimg0.ibsrv.net/gimg/www.thirdgen.org-vbulletin/2000x1504/22ff570e_164a_4825_8b4a_67346cc0f1e6_bb51995ef358429b2538454778022f150ad85a3a.jpeg)
Car: 1986 IROC-Z
Re: T56, TPI stuff, L98 cam
More pics
![](https://cimg3.ibsrv.net/gimg/www.thirdgen.org-vbulletin/2000x1504/180c5087_952e_4a58_b412_487425a37bf4_a0efdb0a84d4b08ab405a160029066e1f6183c51.jpeg)
![](https://cimg5.ibsrv.net/gimg/www.thirdgen.org-vbulletin/2000x1504/326b4d85_2c82_4b29_86c1_bfaa13653713_5e4e423fdacabb7b11102250716cc4d0d7f8d810.jpeg)
Car: 1986 IROC-Z
![](https://cimg1.ibsrv.net/gimg/www.thirdgen.org-vbulletin/2000x1504/f17682de_91c0_4641_bfaf_03f04a9af385_306dd23d485fe2ab9014e97e108dc760912fdc5f.jpeg)
Header bolts, egr solenoid bracket, intake bolts, lots more in a box.
Car: 1986 IROC-Z
![](https://cimg0.ibsrv.net/gimg/www.thirdgen.org-vbulletin/2000x1504/99a7e640_348c_4f1c_aa7b_7ecab16ee613_cd5093c2a81c5efda0a5900803a2a21a2406d0ee.jpeg)
Tpi plenum extension / distributor cover. $5 + shipping
Can you send me more pics to 512 947 5537 or to topduarte@yahoo.com on
TPI plenum, 1992 speed density, t-body opening was opened up. $40
TPI runners, 1992 as-cast set, inlets matches to stock gaskets, outlets matched to oversized gaskets. $20
L98 Roller camshaft
Manny
L98 Roller camshaft
Manny
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Transmission: Pro-built 700R4
Are you selling the AFPR?
Car: 1986 IROC-Z
FPR is good. Will sell with or without the fuel rail.
Car: 1986 IROC-Z
L98 Roller camshaft
Manny
L98 Roller camshaft
Manny
Car: 89 RS
Transmission: 5spd
Axle/Gears: 3.73/LS
Re: TPI stuff, L98 cam, 3:42 Posi
Your add says "3.42 Posi" but I see no details on this, do you still have it by chance? Is it just the carrier/ring/pinion, or entire rear etc?
Car: 89 Firebird
Engine: 355 TBI
Got the posi and gears yesterday. They were well wrapped and very clean good looking parts. A++ person to deal with in my book-Thanks
fullsize fun (04-07-2021)
Car: 1986 IROC-Z
Bump, parts still available. Runners, base, adjustable FPR, cam
Also have a tpi Y intake duct, 3 exhaust elbow-after cat pipe, flanged
Car: 1986 IROC-Z
Bump
need to get this stuff out of the garage, make an offer.
