[FL] TPI SuperRam (Prototype) GM Small Block
Car: 88 GTA
Transmission: 700R4 w/gearvendor Double overdrive
Axle/Gears: Ford 9in 31spline 350G
Engine: 4++,350 & 305 CIs
Re: TPI SuperRam (Prototype) GM Small Block
Any more info about this? Who built it? When ? Why?
Car: 88 GTA
Re: TPI SuperRam (Prototype) GM Small Block L98
Looking to get 1,200 for the whole setup" Box and runners where made from Aluminum, the runners were specially mandrel bent, the stock flanges were cut off stock runners bored out with a mill to accept the larger runners in the id then welded inside. You will get Ported intake/fuel rail/ 30 lb injectors/all necessary hardware for the box and runners/ custom cut and template gaskets/t-handle Allen wrenches/extra O-rings for fuel rail and injectors/map sensor. All vacuum ports and cold start injector have been retained, EGR has been eliminated however you could re-install one if needed? You will need a throttle body (preferably a mono blade type) a 52mm will work and head to intake gaskets. I recommend all gaskets be spray gasket coated! I had this installed on a 3rd gen T/A, there was a little hood interference at he front edge of the box(about a 1/2 inch) a Formula or cowl induction type should work O;K Do not know about a Vette though, never tried it?
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
….. Cool Intake ! … Very nice welding … What is the I.D. of the runners ? …..
Car: 88 GTA
Hi Bob" As of this writing the Ram is assembled, when i get apart again i will get an actual ID Dimension, I just do not remember what it is off hand, If you are familiar what the stock manifold flanges look like you could possibly compare that to the pic of the runners that show the flanges.
355tpipickup
Alternative Port EFI Intakes
07-11-2009 01:49 AM
LaxStreetRacer
31
12-31-2008 04:19 PM
CamaroX84
07-13-2001 03:09 PM
