[NY] Moving clean out
Car: 1988 Trans Am GTA
Engine: 6.0 LQ4
Axle/Gears: 3.43
Moving clean out
Hi guys. Getting ready to move to NJ for work so I am trying to clean out some of my third gen stuff I just have laying around. I will update the list as I go so bear with me. Also so I don't have to spend hours on pics, shoot me a message or e-mail at nickbrehm@msn.com for pics. Some LSX stuff is mixed in too if anyone is interested. Prices do not include shipping. For the bigger stuff I can meet you within 50 or so miles from 12531 or 08640 to save on shipping.
88 Firebird TPI intake (tubes, air cleaner, maf bracket) - $75.00
1 081 Casting cylinder head, fresh rebuild, black POR 15 paint - $50.00
OEM K-member braces (media blated, rust proofed and chassis black) $25.00
82-90 DS headlight Bezel (has red overspray from previous owner) $10.00
82-90 PS Headlight bezel (has red overspray from previous owner) $10.00
88 TPI Air pump - $20.00
A4 Brake Pedal, includes switches - $50.00
T-Stat housing OK shape- $5.00
A4 shifter with PNP, no cable - $35.00
TCI Breakaway 10" Converter, (Part # 243107) Has maybe 500 miles on it - SOLD
4l60/700R4 pans (1 is a brand new stocker off a 4l60E, the other is a slightly deeper one off a truck. Both come with bolts. $10.00/ea
Stainless AIR pipes $10.00
Aluminized Y-pipe, single cat, includes stainless CATCO Cat - $75.00
700R4 less than 500 on rebuild, shift kit, corvette servo, deep pan - $150.00 - ON HOLD (mrestrictrplate)
TPI throttle body (will get you the year and part#, can't recall which one it is) $75.00
88 TPI Base (9th injector), near mint $75.00
Bump stop spacers for 17" rear wheels - $10.00
Poly Sway bar end links (new) - $10.00 - (ON HOLD mizz0313)
85-92 Firebird console, VERY good shape, no seperation. Includes console lid but console lid hinge is broken $100.00 - ON HOLD (mrestrictrplate)
82-90 LH Firebird Headlight door cover, good shape(Red) $5.00
82-90 RH Firebird Headlight door cover, good shape (Red) $5.00
5X Formula WS6 Center caps, 2 good, other 3 are intact but need new emblem $20 for all 5
TPI Plenum, needs cleaning $20.00
TPI Intake manifold with 9th injector (140081005). Needs a good cleaning $50.00
86(?)-92 new style wishbone strut mount brackets $10.00
Brake Master Cylinder $5.00
Delco replacement PCM (88999194), I don't think it has a chip, may still have a PCM for less chip, will have to check Comes with PCM bracket $75.00
All of the following sensors and relays were working when removed, but have been sitting on a shelf for awhile.
VSS Buffer Box SOLD
PNP Switch w/ pigtail $10.00
HEI Module $10.00
Relays $5.00
IAT sensor $5.00
Coolant temp sensor $5.00
Power Window switch (writing is mostly gone ) $5.00
Knock Sensor SOLD
LS stuff:
LQ4 truck Manifolds - $50.00
LS1 241 heads, professionally cleaned, should be bolt on ready, 35K - $250.00
LQ4 317 heads NEW - SOLD
Will update as I go. Some stuff is in NY, some is in NJ. Have pics of most on hand but may take me a day or two for the rest.
-Nick
VSS Buffer Box SOLD
HEI Module $10.00
Relays $5.00
IAT sensor $5.00
Knock Sensor SOLD
LS stuff:
-Nick
Re: Moving clean out
TCI Breakaway 10" Converter, (Part # 243107) Has maybe 500 miles on it - $50.00
700R4 less than 500 on rebuild, shift kit, corvette billet servo - $150.00
88 TPI Base (9th injector), near mint $50.00
VSS $5.00
PNP $10.00
HEI Module $5.00
Relays $5.00
IAT sensor $5.00
Power Window switch (writing is mostly gone $5.00
Knock sensor $5.00
LS stuff:
LQ4 317 heads NEW - $500
-Nick
VSS $5.00
PNP $10.00
HEI Module $5.00
Relays $5.00
IAT sensor $5.00
Knock sensor $5.00
LS stuff:
-Nick
I'm not sure if my messages are going thru but I want to buy the 700r4 transmission and tci converter my cell#7185032475 I can meet for pick in ny or nj and do you have pics
Engine: 6.0 LQ4
Axle/Gears: 3.43
700R4 is out of an 88 GTA, not sure on the spline count will find out. Shoot me an e-mail and I will send pics of the converter and trans later today, Have to pull the trans out of the back of the garage.
-Nick
-Nick
Engine: 6.0 LQ4
Axle/Gears: 3.43
Here ya go, Trans comes with TV cable and deep pan, but not with the Exhaust and torque arm mounts. And the trans/converter are a 30 Spline with a lock up
-Nick
-Nick
Engine: 6.0 LQ4
Axle/Gears: 3.43
The VSS box goes between the VSS sensor and the Gauge. It's under the dash. I think it's purpose is to translate the signal correctly from the sensor so your speed works correctly
VSS box, PNP switch and HEI module are sold
Engine: 6.0 LQ4
Axle/Gears: 3.43
I am out of town for work after Monday until Feb 17th. If you guys want anything LMK and I'll mark it down, but won't be able to ship anything until I get back
-Nick
-Nick
Engine: 6.0 LQ4
Axle/Gears: 3.43
I would like to apologize for not updating this, I was down and out with the Flu and then Uncle Sam unexpectedly sent me back out the door sooner than planned. Currently overseas, will be back Mid-March. Everything listed is still available
11-08-2009 07:23 PM
