[IL] 700r4 w/ converter and shifter
1 Post
Car: 1988 Firebird Formula
Engine: LS 6.0
Transmission: th400
Axle/Gears: ford 9in 4.11
Selling 700r4 built to handle 600 horse. It sat behind my LS2 with roughly 600 horse. Has 5 pinion planetary gear set, newer clutches, all new servos from PATC, TCI constant pressure valve body, TCI shift kit, and poly mount. Transmission only has a 2-3k miles on it.
Will come with....
new TCI street fighter converter 3000-3500 stall, non lock up. PN 242963. Roughly 60 miles.
B&M megashifter with new handle w/ button and shift cable.
Lokar detent cable
Weights to change shift points depending on power/stall/gear ratio.
Only thing it it will not come with is dipstick tube. Currently holding in all the fluid.
Asking 1600 As a package. local pickup only.
tcollinsjr
12-25-2017 07:46 PM
Camaro86IrocZ
11-20-2014 09:49 AM
Ilike2stroke383
02-27-2010 11:12 AM
Bruce Amighty
05-14-2008 06:19 PM
92 Formula
08-22-2002 04:44 PM
