BBK 52MM Throttle Body, Fuel Rail w 30#, stock Runners
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
This used BBK Power Plus Throttle Body was installed on an engine project in a car that was broken in and immediately put on a trailer from Washing, DC to Charleston, SC. The car was stored for eight years with trips through the neighborhood for TPI tuning before being removed in 2016.
INCLUDES the Throttle Position Sensor, Idle Air Control Valve and stock lower TPI IAC/water port housing. I believe this is 52MM as each port is just over 2 inches ~ 52mm.
$200 shipped to continental United States only.
This used stock TPI fuel rail has eight (8) used 30# FORD Red Top injectors. Working on 406ci engine when removed.
Used stock TPI runners. Glass beaded finish.
$100 shipped to continental United States only.
Car: 1969 Z28
Engine: 406 TPI
Axle/Gears: 3.31
Re: BBK 52MM Throttle Body, Fuel Rail w 30#, stock Runners
BBK Throttle body SOLD to forum member and shipped out this morning.
Stock fuel rail and Ford 30# injectors lowered to $175 shipped.
Stock runners lowered to $75 shipped.
CONUS only.
CONUS only.
