Looking for F.A.S.T System.
Car: 1985 iroc z28 T-top
Engine: 383
Axle/Gears: Stock
I'm looking for New or Used FAST system. PM me or call or text 208-512-0570 Thanks Brent https://www.thirdgen.org/forums/imag.../attention.gif
Car: 1988 pontiac Trans Am GTA
Engine: DFI,Single Plane,200cc Dart I.E,355
Transmission: Th400 PTC converter
Axle/Gears: Stock Ausie 9 bolt w/3.45 gears
Re: Looking for F.A.S.T System.
I have a FAST classic SEFI (sequential fuel injection), born date of 2004, the system has a Wideband O2 and datalogger built in, usb cable for computer to ecu, Also includes c-com cd and all sensors... also have an MSD distributor for it that has both cam sync and crank sensor connections.... if you need an intake set up as well I have a world motown EFI manifold, Holley 1000cfm 4150 flange TB, 37lbs injectors, and regulator....
Fast... $700obo
Distrib.... $450
Intake setup...$850
Or sell it all for $1800
Selling because I'm doing turbo LS in the car now and the motor is carb'd in another car of mine
Fast... $700obo
Distrib.... $450
Intake setup...$850
Pics should be attached
Engine: 383
Axle/Gears: Stock
It looks like a nice system but i'm going to hold out for a firstfuelinjection.com system. Thanks
I bought mine off of ebay last winter for $1200. It's an ez efi 2.0 retro kit and has been a pretty easy install so far. I also bought the matching dual sync dist, e6 box, and e92 coil. Haven't had time to install those yet.
Self tuning and mated up with all the factory tpi stuff.
