[AZ] AN heater hose setup
Old 07-11-2016, 04:44 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Selling my AN heater hose setup because, well I don't need a heater in Arizona. It is 3 years old and has 1000-1200 miles on it. The hose from the intake to the heater core is a 10 an and the hose from the water pump to the heater core is a 12 an. The 10 an hose is brand new and includes 3 feet. So there is a 10 an hose, 90* 10an hose end and 10 an to 1/2" NPT fitting. There is a 12 an hose, 12 an straight hose end and a 45* 10an to 1/2" NPT fitting. For the heater core connectors you can use worm clamp style, an AN covered worm clamp or you can solder on a connector to your heater core.
There is no comparison between an AN heater hose setup and a run of the mill black hose setup. An AN setup will also ensure that you never have a leak again.
Each individual connector starts at about $10 so when I pieced it together new it was at least $75. I'm willing to sell it for about 1/2 what I paid, $35 plus shipping which will probably be $10-15. 3' of new 10an alone is $15, this is a steal.
These take up almost no room in my garage so I'm not in a hurry to sell them and I won't reply to a lowball offer.
PayPal only.
Old 07-11-2016, 06:49 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Re: AN heater hose setup
What Intake was this from?
Old 07-11-2016, 07:52 PM
Tibo's Avatar
Car: 1991 Z28 Vert
It didn't come with an intake, I had to buy the pieces separately. I was using a single plane efi intake setup so this will work with carbureted engines, single plane efi, stealth ram for sure.
Old 07-11-2016, 08:08 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
I have a first tpi intake.
Old 07-11-2016, 09:24 PM
Tibo's Avatar
Car: 1991 Z28 Vert
You would have to determine if this works for you.
Old 07-11-2016, 09:27 PM
Tibo's Avatar
Car: 1991 Z28 Vert
This is the best picture I have of them installed. The intakes 10an line goes around the fuel rail and over the cover. The pumps 12an comes up and follows the other hose over the valve cover.
Old 07-12-2016, 09:10 AM
TGO Supporter/Moderator
TGO - 10 Year Member
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
I'll buy it if that other dude isn't interested.
LMK. Zip code is 03079.
I've been troubled by my existing disaster of hoses since I moved the blower to the passenger side. My brand new aluminum water pump is leaking so I have to drain the system anyway.
-- Joe
Old 07-12-2016, 03:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
-- Joe
He hasn't made any indication that he wants to buy them or I need to put them on hold. First come first serve. Plus, as far as the internet goes I kinda "know" you. Pm me your info and shipper preference and I'll reply back.
-Mark.
Old 07-12-2016, 04:01 PM
crossrush's Avatar
Car: 1986 Iroc z
Axle/Gears: 3:42
Did you check your pm's?
Kylej68
03-31-2016 05:40 PM
mikeyt
03-21-2016 06:53 PM
Pat
Aftermarket Product Review
04-02-2001 07:35 PM
david auster
03-08-2001 09:37 AM
johns84bird
12-01-2000 11:25 PM
Quick Reply: [AZ] AN heater hose setup
