[WA] 1992 Camaro rear axle assembly $100
Hi. I have the rear end I pulled from my '92 RS Camaro. I believe it to have the stock 2.73 gears. It's an open differential with drum brakes. The only thing you should need for it would be either new or your old parking brake cables and the brake hose junction block. It worked great in my car with about 130k on it, I just swapped out to something more performance oriented. I also have the stock control arms and panhard bar in case someone needs them. I'm in Vancouver, WA, just north of Portland, OR. It would probably need to be local pickup because of the size.
Whoboy580
03-29-2016 03:12 PM
