87' 305 TPI Engine for sale
Car: 87 Trans Am GTA
Engine: 5.0
Removed from my 87 GTA 5spd. Running great before removal. Has Air pump(smog) delete. Fairly low mileage +/- 70,000. Located in Ozark, AL 36360 (SE) Pick up only. Asking $600 OBO. PM for contact info.
-Adam
Engine: 5.0
Re: 87' 305 TPI Engine for sale
This 305 with the T-5 was actually just a quick if not quicker than a 350 auto. This could obviously go on either transmission with the right bell housing. As far as demand all depends if people want to keep their car original or not. Would rather see this engine go to good use than a junk yard ! Great engine lot of good components. Come pick it up ! Also have a ton more parts you could check out if you come this way.
Yes, I aware of the 5 speed/auto. It's going to be a 700R4. I would need to verify a few items making sure it is an 87 F code engine with 5 spd. Obviously everything is a little risky buying a used engine. I've seen a lot swapped & even crate motors in cars I've bought thinking it was 100% original.
Can you get me a shot of the stamping on the front (yes front) of the engine. When looking at it from the front the little stamping on the left side if the block just in front if the left head....I want to see date code VIN code please.
Engine: 5.0
I know, it is just there is nothing on the front that I could find. This is looking directly below the alternator.
That thing off to the last side in my picture is actually the front of a set if aluminum heads on the block. This is directly UNDER the alternator on your enginet. It is facing up. It tells me the day, Date & year this engine was produced
Engine: 5.0
Definitely some shoddy stamping work on lower numbers (stamped 3x times?!) but I finally found it!
Engine: 5.0
Sounds good. Let me know and like I said I have plenty of other third gen parts in great shape you might find why you are here. Plastics, TTops, Seats, Hood, Bumpers, TailLights and ETC.
I've obviously been able to trace this number but that SFX OR SEX doesn't pop up yet on anything I have. Could be the "X" is for Pontiac. I'm still running #s but fI rat set look right.
14093627 Small Block V8 1987-1991 305, 2 bolt, roller cam, 1-piece rear seal
