[TX] Random Parts from L98 removal
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
I took out the L98 from my 1LE for my LS swap and these are some of the parts I have for sale. All prices are plus shipping. Engine and exhaust is local pickup only.
Sold-l98 Long block, 155k miles. Ran good, no smoke have a quick video if interested.
$200-Accessory Drive setup, includes brackets, crank pulley, alt, ps pump, air pump, and waterpump if you want it.
Sold 91 TPI intake setup, Throttlebody, upper plenum, runners and base. Includes fuel rails and injectors.
Sold Distributor
Sold MSD coil, PN8226 less than 1k miles since installed
Sold New MSD streetfire plug wires, still in the box. MSD-5570
$50 K&N Air filters PN 33-2008-1 that's both for $50. These are used but in good shape just need to be recharged.
$350 complete dual cat magnaflow stainless exhaust. System was completely welded together. I cut it in 2 spots making 3 easy to put back together systems. heres links to the two systems it is. $1k worth of exhaust.
http://www.summitracing.com/parts/mpe-16829
http://www.summitracing.com/parts/mpe-23479
Let me know if you need pictures of anything.
Sold Distributor
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Re: Random Parts from L98 removal
I'm interested in the spark plug wires if they are already assembled and there is no crimping and cut to fit required
Moderator/TGO Supporter
1 Post
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
I'm in need of the underhood smog components, including both AIR tubes, mounting brackets, hoses, etc. PM sent - Please send photos.
