[WI] Parting out 87 Iroc 305TPI auto
just as the title says car was a 305 TPI auto black interior hardtop if you need something just ask I stock thousands of parts if its not on this car it could have been on another I had the wiring harness is gone but most other parts are still here
Re: Parting out 87 Iroc 305TPI auto
I'm wondering if you have the tpi egr solenoid if so. Specifically looking for a 1989 camaro 5.7 tpi egr solenoid. How much would you want for it shipped to 93640.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
I am missing some bolts/hardware from the front end. Is the body hardware in excellent condition or rusty? I am looking for the nuts/bolts/clip-nuts/plates connecting the front GFX (#47) to the front bumper cover (#46) and air guides (#65 & 68), as well as the air dam.
How much for a bag of bolts?
I saw in another thread the GFX-to-fender stud-plates (#48) are not available. Fortunately for me, only one of the studs bent over on disassembly, so 5 of 6 are good.
Car: 92Camaro 89 Blazer
Engine: 3.1L Turbo
Im looking for a 7730 ECM (with prom) shipped to 83676. maybe wiring harness as well.
MantyZ28 do you know if the Tuneport engine accessories(a/c, alternator, Power steering, etc) will bolt up to a 3.1 V6? What would you charge for all the front accessories?
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
tachometer available?
thanks, Greg
thanks, Greg
Car: 2011 Camaro 2SSRS w/ Procharger
Engine: 6.2 LS3
Transmission: M6 TR6060
Axle/Gears: 3.45
Stock torque arm mount with all 3 bolts? The mount the hooks up to the tranny, and the torque arm bushing sits in. I imagine it's the same for the 700r4 and the t5. I have a t5 and I need a stock mount. Bushing condition is irrelevant.
Engine: 3.1L Turbo
Hey, we have a problem. The 7730 you sent me has a V6 memcal in it. Strange that it came from a 305 TPI. How are we going to fix this?
Car: 1987 IROC-Z
Where in WI? With the exception of the color of the interior, and the hard top, its her twin. There are quite a few things i'm looking for, but to name a few...
Is she AC, or just heat?
im looking for most of the parts to the black interior.
Car: 1986 Z28
Engine: 5.0 TPI
Axle/Gears: 2:73
what do you want for the posi? is it clean?
And does anybody know if I can put drum brakes on a disc rear end? looking for the easiest swap, and keep mine origional looking. Tons of info going the other way.
Car: 1987 IROC-Z
hmmm, i was hoping you where closer so i could just swing by and take a look... but if i'm buying parts, its not too far to pick them up.
list of parts i need that you might have...
interior
driver side kick panel
both door panels w/hardware (for non-electric windows)
rear seat backs
read drivers side side cover /carpeted (where the DS sail panel mounts to and behind)
plastic trim under passenger side door
hangers that go through the sail panel
seat belts
visors
Engine
distributor cover for TPI
misc
non-ac fan and housing
interior
rear seat backs
seat belts
visors
Engine
misc
Car: 1989 camaro iroc-z
Engine: L98 350 5.7 bored 0.30 over
Transmission: 2400 stall lockout
hope all is well , wondering if you had any non rusted rear impact bars? how much? thanks
89irocz355
101
09-19-2016 04:05 AM
