[ON] 9 Bolt 3.70 Motive Gears & Master Install Kit - NEW IN BOX
NEW IN BOX Master Install kit #Motive R7.75RMKT for 9 Bolt Borg Warner M78 Australian axle.
$75 shipped - Kit Is missing some parts (underlined in the list) - see below
Install Kit includes:
Timken Carrier Bearings SET47 for cup & cone OR LM102911/LM102949 - missing cups only
Timken Pinion Bearings INNER HM89410/HM89446
Timken Pinion Bearings OUTER HM88610/HM88649
Carrier Shim Kit
National Pinion Seal 16545
Crush Sleeve
Pinion Nut 3/4-16
Pinion Shim Kit
Ring Gear Bolts & Loctite
Gear Marking Compound & Brush
85g Tube RTV
Missing parts can be bought from RockAuto:
2x Timken Carrier Bearings SET47 (cup & cone) $9.17 each
Pinion Seal 16545 $8.52
Pinion Nut 3/4-16 $1.11
Total missing parts: $29.97
So you get the complete kit with your missing parts for less than $105 shipped, plus a few bucks for shipping from RockAuto.
Carrier Shim Kit
Crush Sleeve
Pinion Nut 3/4-16
Pinion Shim Kit
85g Tube RTV
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: 9 Bolt 3.70 Motive Gears & Master Install Kit - NEW IN BOX
http://www.ebay.com/itm/like/281727726637?ul_noapp=true&chn=ps&lpid=82
zrated383
10-29-2015 07:11 PM
86IROC112
10-13-2015 03:59 PM
