[NC] T5 swap package
T5 swap package
I've got pretty much a complete T5 swap for sale. I was going to put this in my Firebird but have changed my mind due to recent events. Included are:
World Class T5 from an '89 Formula with just over 89,000 miles and was working properly when it was removed from the original car. This includes the bellhousing, inspection cover and pedal assembly from the same car.
New Hurst shifter with 2 shifter *****
Reman starter
Firebird shifter plate with a carbon fiber wrap
New clutch fork
New pilot bushing
New electrical pigtails from TPIParts.com
New ARP hardware for the flywheel and clutch assy.
New steel bearing plate with peel-a-shim kit
New Earls braided SS fluid line from m/c to slave cylinder with fittings
New clutch master cylinder along with 2 used spares
New slave cylinder
New floor shifter boot and one used boot
New Sachs performance clutch kit and flywheel
All master cylinder and reservoir mounting hardware and brackets including the bracket that mounts the reservoir to the brake booster
Catalytic converter transmission/exhaust hanger
'91 TPI 305 PROM (latest revision) with code 32 disabled from Tuned Performance
Various other bits and pieces included
This package is pretty much complete with the only thing I had left to do was have the T5 gone through and freshened up just for my own piece of mind. Asking $1000 but willing to negotiate and as far as shipping I'd prefer local pickup or a possible meet half way. If shipping is involved we'll have to work that out.
Reman starter
New clutch fork
New pilot bushing
New slave cylinder
Car: 1985 Pontiac Trans Am
Engine: 305 (5.0L) TPI
Axle/Gears: 9 Bolt Borg Warner Posi-traction
Re: T5 swap package
Are you willing to sell the parts separate?
hectre13
12-11-2023 08:14 AM
