[PA] 4th gen posi disc brake rear4.11gears Eaton posi
I have a (3 channel) 10 bolt posi disc brake rear out of a Lt1 powered 4th gen F-body. It has an Eaton Limited slip differential, (Yukon gear) 4.11 gears, T/A performance stud girdle cover, stock axles. Rear has 30k miles on it. Posi unit works good, gears look good. It also has an aftermarket double adjustable pan hard bar w/ heim joints on it. Asking $500 B/O.
This rear was in my 83 Firebird which was running and driving before I pulled it apart.
located in Hatboro, Pa
Car: '92 Camaro
Re: 4th gen posi disc brake rear4.11gears Eaton posi
Interested for sure, can you give a quick rundown of anything that needs to be done to get this to fit in a 3rd gen camaro?
hectre13
12-11-2023 08:14 AM
sailtexas186548
01-19-2016 12:21 PM
novaderrik
08-10-2015 12:44 PM
1992 Trans Am
08-08-2015 08:16 PM
