[CA] JEGS 514032 SBC Cylinder Heads
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
I am selling these heads that I bought when I was building a new engine to replace the 305 on my 1984 Trans Am. I bolted them up to the new short block and put on the intake gaskets, but I ended up rebuilding the original L69 heads and installing those instead. These heads are new and have never been on a running engine. They have some head gasket residue.
Includes the parts that originally came with the heads:
2 - Cylinder Heads with valves installed
16 - 1.44" Dual Valve springs
16 - Valve spring locators
16 - Valve spring retainers
16 - Valve spring retainer locks
16 - 0.060" Valve spring shims
16 - 0.030" Valve spring shims
The only thing missing are the valve stem seals since I had to remove these when I put in a different set of springs for my new engine.
Here's the page for the cylinder heads at the JEGS site.
These heads are made by Pro-Filer Performance for JEGS. You can find very good reviews on the Pro-Filer heads.
Asking $900 OBO. Would prefer to sell locally in the West LA area.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: JEGS 514032 SBC Cylinder Heads
I don't se anything pertaining to valve covers.
Center bolt maybe? ('87 & up)
1 Post
Both styles can be used. They have the holes for both perimeter and center bolt valve covers.
Chuck84TA
07-15-2016 09:05 PM
Mickeyruder
09-02-2015 02:45 PM
NinjaNife
08-23-2015 11:49 AM
