[ON] Innovate LM-1 & LMA-3 Wideband - New In Box - SOLD
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Innovate LM-1 & LMA-3 Wideband - New In Box SOLD
Wideband with datalogging and Aux box with 5 built in sensors with datalogging.
LM-1:
Fully digital provides exact air/fuel ratio,self-calibrating. The LM-1s measure data 12 times per second for up to 44 minutes. The data can be downloaded to a PC with the included serial cable and software so you can graph multiple sessions. Instead of spending hours tweaking and tuning your carburetor, use the LM-1s to get the information you need, tune your carb, and be done. Tuning a fuel injection system involves many variables, but the optional auxiliary-input cable provides up to 5 simultaneous readings, for a more complete view of an engine system's performance. For example, you can measure and graph specific air/fuel ratios in relation to rpm, MAF, MAP, TPI, and more. The LM-1 kits include a Bosch wide-band oxygen sensor and cable, cigarette lighter power adapter, serial cable for PC, 9 V battery, exhaust bung and plug, quick-start guide, and a CD with software and manual.
LMA-3:
http://www.innovatemotorsports.com/products/lma3.php
The AuxBox attaches to the auxiliary input of the LM-1 or it can be integrated into the MTS serial chain. The AuxBox has 5 built-in sensors. The 5 internal sensors are: Manifold Air Pressure (MAP or Boost), Cylinder Head Temperature (CHT) or Exhaust Gas Temperature (EGT), RPM conversion (from a tach signal or inductive clamp), Acceleration, and Injector Duty Cycle (or Dwell). The internal MAP sensor is a 3-bar absolute pressure sensor, providing accurate data up to 44.1 PSIA. The temperature measurement circuit features a K-type thermocouple. The internal accelerometer features 2 axis measurements for a variety of mounting options. The AuxBox also includes 5 external inputs for connecting external sensors in lieu of the internal sensors. This allows users to log data from external sensors like TPS or MAF.
LM-1:
LMA-3:
camaro1185
10-26-2015 06:51 AM
MarineIROC
Southern California Area
09-06-2015 04:55 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-06-2015 06:23 AM
