Holley HP EFI Controller
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
... SOLD ... SOLD ... an unused Holley HP EFI ECU only ... this was a spare for a race team that switched to a Holley Dominator Controller ... harnesses are available for just about any EFI set-up that you could imagine ... the HP has a self learning capability that minimizes the need for laptop tuning ...... $750 shipped .............
Car: '87 Vette C4
Re: Holley HP EFI Controller
...... Still available .................
Car: 1991 z28
Engine: sbc383,chad speier222cc heads
Transmission: built 700r4 Yank 3600 stall
Axle/Gears: dana 44 3.73 gears
Had to try lol no one else was pm'ed...
Car: '87 Vette C4
............ Still available ................
Car: '87 Vette C4
................ Weekend bump .................
Car: '87 Vette C4
..... Bump it ... How about $750 shipped ? ..............
Car: '87 Vette C4
..... No , unfortunately it will not ... Holley incorporated some additional features into the HP ... wide band O2S for one ... that required an all new harness configuration ... the Avenger , HP , and Dominator all share the same harnesses which makes it easy to upgrade from the HP ... the harnesses needed for a typical MPFI set-up ( HSR or TPI ) will cost around $500 from a place like Summit or Jegs , there are some E-bay vendors that will give you a package deal ............
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
You can piece together the harness for your particular application on Amazon cheaper than Summit/Jegs or ebay if you invest a few hours online figuring out part numbers. That's what I did for the Avenger retrofit going on my car.
GLWS
GLWS
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
This is a great system and great price considering its about $950 new just for the ecu.
I would buy it as a replacement for my HP ECU as my usb connector broke and I have had to resort to using an SD card in my handheld for tuning Right now, replacing the ECU is not my priority.
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
Does any know the parts list to make this the same as a complete 550-601 kit? I'm curious how much id save buying it like this versus the whole kit. Does ur ecu include a controller?
Car: '87 Vette C4
To make a 550-601 kit you need ... 554-113 ECU ... 558-101 TPI/SR harness ... 558-200 V8 injector harness ... 558-304 HEI ignition harness ... 558-308 Main Power harness ... 558-409 USB Cable (you probably have several of these already) ... 554-101 Bosch Wideband O2S ... GM MAP , IAT , ECT , and IAC ( you can use the ones you have on your TPI set-up ) ... the touch screen is not included with the 550-601 kit , but is available as 553-103 ... you will need a laptop to initiate your base tune and establish some operational parameters ... once you're up and running the Holley HP will automatically adjust fuel maps to your pre-set AFR targets ........ closed loop learning so to speak ..........
Car: '87 Vette C4
............. Still available .................
Car: '87 Vette C4
........... T T T ...................................
Car: '87 Vette C4
.......... Bump it up ...........
Hotrodboba400
12-10-2019 07:07 PM
