[TX] Hyd. Roller Cam and Lifters
I've had these in the closet for a while now, and probably won't use them anytime soon, so, I thought it best to sell them.
Cam was run on the dyno only. And I decided to go with a smaller camshaft better suited for turbo application.
Crane Hyd. roller cam. Small base circle (a must for stroker engines) pressed on gear, which means no need for a melonized gear.
Crane Cams Part number : 109641
Cam specs: 234/242@.50
Lobe separation : 112
Lift: .539-.558 = with 1.6 rockers .575-.595
Compression : 10.0-11.5
Power range : 3000-6500
Dual pattern rough idle. auto requirement :3000 stall converter
Advertised : 296/304
Firm $200.00 plus shipping.
G.M factory hyd. roller lifters.
Used on the dyno. very little time running.
Firm: $60.00 plus shipping.
Car: 1987 Iroc Z
Engine: 355 TPI Fully Built
Transmission: Borg Warner WC 5-Speed
Axle/Gears: Stock Posi Rearend
Re: Hyd. Roller Cam and Lifters
would you do $50 for the lifters?
thanks, Greg
thanks, Greg
My bad for not mentioning it. These lifters did sell with another camshaft I had. The camshaft in this ad is still available. I also have the roller lifters that I pulled out of the low mileage 92 5.7 Z28 Camaro. Those were working perfectly before I pulled them. I'll take $40 for those lifters plus shipping.
dimented24x7
09-06-2015 03:51 PM
