[TX] McLeod Clutch & Flywheel - Gen I SBC (2pc) to LT1 T-56 Transmission Conversion CHEAP
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Re: McLeod Clutch & Flywheel - Gen I SBC (2pc) to LT1 T-56 Transmission Conversion CH
can that clutch and pp be used without that throwout bearing?? Im about to buy the flywheel i need, same as yours but for externally balanced motor....and need a clutch setup to replace this stock crap i got with my swap.
Can you text me please?
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
How does this work with the LT1 pull style stuff?
Car: 86 Z28
Axle/Gears: 3.42 posi
LT1 motors are a 1 peice rear main, along with the 86 and up blocks. 55-85 are two piece, so this flywheel will only work with 55-85 or 86+, not both.
If it will work for the 55-85 block I may be interested in it.
Car: 86 Z28
Nevermind, this will only work with a converted lt1 t56 not a stock one since the stock is a pull style.
http://www.summitracing.com/parts/mc...0/applications
Can you please text me if you are interested?
361-571-1026 Dean
BlackphantomZ28
04-24-2016 08:14 AM
rsrmoore
08-07-2015 08:44 PM
