[OK] Auto XRAY
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Auto XRAY
Auto XRAY, auto diagnostic tool. It is an excellent scan tool that not only pulls and erases codes, but it also what all of your sensor readings are. You can, with this tool, tune your motor as fine as you care to. The tool gives you a (going from memory here) a 1-160 number, or 1-100% readout, and it tells you what number you should see. As an example, the device may say any number from 80-120 is where you need to be for your car to run right. You can tell that an 81 will let the car run, but tuning the number up to 100 would put your car at the optimal level for maximum performance. You get 119 results when you run the scan. Most are off or on detections, but there are many that give you a numerical feedback.You will be able to tell what your computer sees. If you are having trouble with your car, this may be just what you need to see what the problem is. Maybe your computer thinks the Wastegate Bypass is on when its actually off. With this tool you see what the computer sees. Invaluable right? The tool is currently configured for thirdgen Camaro/Firebird (and many other vehicles that have the same connector/computer, but adapters/updates are available for other vehicles.
I had great plans to dial my car in to the teeth, but my chronic back pain keeps me from even driving my car as much as I would like. I am now in a situation where I need money, and I have to let a few things go. Since I have had this tool for 2 years and all I have done is a preliminary scan, its time to see if I can sell it.
I am asking $100 for the tool, and I will cover the shipping to anywhere in the lower 48 states. If someone outside that area wants to buy it, I will still ship it, but you will have to pay actual shipping charges. You get everything in the picture (and a new AA batteries x4). Nothing more, nothing less. If I can't get my asking price, I will probably take less as I need the money.
PM me, or post on this thread with any questions, or offers to buy. 1st person to come up with the money gets the tool.
![](http://img191.imageshack.us/img191/6918/img5923n.jpg)
Engine: 5.7 TPI
Re: Auto XRAY
It doesn't really have a model number. Its an Auto XRAY, EZ LINK Automotive Diagnostic System. It is Part Number 705-0001-002A. Within the device itself you can configure it to your specific year, and motor size. Here is a picture of the back side. Sorry for the poor quality.
![](http://img26.imageshack.us/img26/3685/img5928s.jpg)
Car: 85 & 87 Monte Carlo SS/80 El Camino
Engine: 305/350/454
Transmission: 2004R, 2004R, TH400
Axle/Gears: 3:42, 3:73, 3:23
Re: Auto XRAY
Sorry I missed the EZ link part.
I have an auto xray 3000.
Not sure of the specs on this particular one but I love mine.
For anybody who wants to tune your car this is a great unit for a great price.
Car: 91 Z28
Engine: worked crate 350
Axle/Gears: Z posi
Re: Auto XRAY
So this will change fuel duration and timing for fuel injection?
Can this be used to correct individual cylinder ping?
Not familiar with car FI tuning... coming from the motorcycle world
Engine: 5.7 TPI
Re: Auto XRAY
The unit will not make any changes. It will only give readings. Make a change, take a reading, repeat till perfect.
Engine: 5.7 TPI
Re: Auto XRAY
will you take a hundred shipped? email me at dwcactusaz@q.com
since I emailed you a few days ago I assume you changed your mind. If anyone wants it at the same price I will take it.
first money gets it, I don't want to hold it at this price.
Engine: 5.7 TPI
Re: Auto XRAY
If anyone is interested, for an additional $10, I will throw in the following:
1 2012 Red IROC Hot Wheel
1 2012 Black IROC Hot Wheel (your choice with banner or not if you don't specify I will pick)
1 2012 KITT Hot Wheel
all Hot Wheels will be new, in the package the way they come off the peg. They are from my personal stash that I already own and will ship with the Auto XRAY. Meaning I do not have to go and find them, I already have them.
Engine: 5.7 TPI
Re: Auto XRAY
It looks like ***.net email servers are down. If anyone has attempted to email me I will not get that email until they fix whatever happened. PM me, or post here if interested.
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: Auto XRAY
Does it have a standard ALDL connector that I can use on my 1988 formula 350? Will it display things like TPS voltage, coolant temp and other sensor readings in real time?
Engine: 5.7 TPI
Re: Auto XRAY
The device connects to your OBDI (OBD1) with the ALDL CABLE. This listing comes with the GM connector that will fit any GM vehicle from 1982 to 1995.
You can read real-time data, or take a snapshot.
Coolant tem will read from -40 to +389
Throttle sensor voltage from 0 to 5 volts
I hope that covered your question sufficiently.
Engine: 5.7L TPI
Re: Auto XRAY
The item arrived Monday. I left you some positive classified feedback, thanks.
Linson
10-01-2015 09:50 PM
