[CA] TPI, TBI, Borla, Accel, FelPro, K&N, etc...
Car: 1988 Camaro Convertible
Engine: 355
So I finally got some of my health back and it’s time to liquidate this stuff so that I can actually get my car running. I apologize if you hit me up before and I never got back to you. Its hard responding and shipping out parts from the ICU I’m definitely into trades, so please review my trade list below, though cash or paypal are always good as well. If paying by paypal, please add 3%. All parts that include shipping will be so noted. Also shipping is for the lower 48. Anything outside of that will have to be quoted separately.
Make sure you check out my other ad’s for exterior and interior pieces for Camaro and Firebirds so that I can combine shipping if you’re looking for multiple parts.
Potential Trades:
Ls3 Valves – must be hollow stems!
LS3 heads / L92 Heads
LS3 rockers
Comp Cam Trunion Upgrade for LS3 rockers
TSP 224r cam (or Equivalent)
Fbody LS1 Front Accessories (brackets and/or with accessories like AC compressor)
4th gen 98-02 Camaro Dash Assembly
Corvette Y2k wheels (17’s front/ 18’s rear)
2” Spacers (To run Corvette wheels on Camaro hub)
Nick Williams Throttle Body (LS3)
LSx engine adapters (and/or motor mounts)
Tubular K member
Koni Yellows
Spohn Suspension Parts (thirdgen Camaro)
Engine Appearance Parts
Spark Plug Wire Looms
Billet Specialties Part Number #69520 AND Part #69600 – Both NEW in package
Jegs: $71.98 + shipping - My asking Price: $60 shipped
Spark Plug Wires
Accel SuperStock 4040R – 8mm Red - NEW
Jegs: $35.99 + shipping - My Asking Price: $28 shipped
Tuned Port Injection
350 Block
"010" block. I believe this is one of the High Nickel blocks. I’m also including the Crank. It’s just been magged and tanked and currently has a standard bore, however it will need a bore and a hone to at least .020 over. Great block for a 383 build. Asking $350 – This will need to be a local transaction.
Complete TPI Unit – Build to Suit!
Ok so I have quite a bit of TPI parts. I would like to sell this as a “complete unit” with you matching the combo you want.
Here’s what I have:
Plenum – 14081006
Lower Intake
(1) 14081005 – This has been cleaned up and possibly even painted. It looks brand new.
OR
(2) 10066015
Runners – I have two sets of stock runners, with some small dimples on them.
TPIS throttle Body – might be stock with a TPIS plate, but if I recall it’s actually a TPIS. Let me know how to confirm and ill do so.
Fuel Lines
(1) – Fuel Rail from a 1988 L98 (Part # 17087265), includes TPIS billet AFPR and (8) matched 22# Bosch Injectors (part # 5235302)
OR
(2) Fuel Rail from an 87 TPI (part #17087264) with a stock modified AFPR and NO injectors
Fuel Injectors
(8) LT1 24# injectors – 17095004
I believe these were all matched and blueprinted, but its been awhile since I purchased them.
ECM’s
I have a 7165 (part #’s 7-7165, 099MG, 07716500992530162) It says “Remanu” on it, so I assume it is. OR
A Speed Density 7730 ECM
Wiring Harness
I believe it’s a SD wiring harness, but I’ll need to double check on that.
Stock TPI bolts included
Let me know how you would want the above put together and your zip code and I can get you a “price shipped” to your door step.
SuperRam Gasket Kit
74196G – NIB
Jegs: $39.99 + Shipping - My Asking Price: $25.00 shipped
Front Accessory Brackets – NEW from GM
GM Tensioner – 10055798
Alternator and Power steering bracket - 10105212
AC Bracket - 10055800
I paid over $300 for these, as I bought them new from GM – these are NOT aftermarket pieces. Check Pace or summit for pricing. These were never used or installed and are BRAND NEW.
I’d like to get $200 shipped
FelPro Intake Gaskets
NEW in package – MS 93317 I believe this is for TBI and TPI engines, but please verify.
JEgs: $16.99 + shipping - My Asking Price: $15 shipped
Summit Racing Aluminum Water Neck
POLISHED - 360 swivel (part #SUM-371101)
Summit Price: $29.88 + shipping – My Asking Price: $20 shipped
TPI Dual Fans
These are the fans with the motors, I don’t have the top and bottom piece.
Asking $100 shipped
ARP intake bolts
134-2101 – Brand new - Intake Manifold, Chromoly, Black Oxide, 12-Point Head, Chevy, Small Block Kit
Jegs: $20 + shipping – Asking $18 shipped
Felpro Head Gaskets
(Part #1003) Thickness .041'' - Volume 9.1cc
Jegs: $36.99 EACH + Shipping – My Asking Price: $63 shipped
TV Cable
Part #10163879
$25 shipped
TPI Throttle Cable
Part #10163822
$20 shipped
TPI EGR Valve
part #17085813
$30 shipped
Emissions Bracket
part #14073420
$25 shipped
Flexplate
Part #14088761 ( 1986+ )
168-Tooth, External Engine Balance, 10.75 in./11.50 in.Bolt Pattern, 1-Piece Rear Main, Chevy
$75 shipped
Water Pump Pulley
Part #10055880
$25 shipped
TBI Parts (Throttle Body Injection)
K&N Air Filter E-1450 – A14D85 (# on part) AND K&N chrome air filter Lid
This was used for about 2000 miles before I pulled the engine. The lid has some slight lip issues, I think which came from fitment with the Accel distributer I had at the time. Still looks great though. I think I’ve got the “kit” to go with it. If I find it, I’ll throw it in for you.
Jegs: $65.99
My Asking Price: $35 shipped
(Copy from above) FelPro Intake Gaskets
I believe this is for TBI and TPI engines, but please verify for yourself.
Miscellaneous Performance / Suspension
(2) Borla 2.5” in/out Mufflers
There is a spot that will need to be rewelded where the hangers were attached, but you’d have to weld that spot any way to hang them. Really low miles and clean.
Online price: $200 + shipping – My asking Price is $150 shipped.
Sway Bars
I believe they’re 36mm/24mm from a GTA- They need to be cleaned, but other than that they’re ready to go and in good shape. Can take pics and confirm sizing. These would be very hard to ship, but willing to give it a shot.
Asking: $125 (+ shipping if you want them shipped)
Stock Thirdgen Tire Jack
(Part #’s 14094435A and 14098160) Great for a resto or just to have for emergencies.
Asking price: $35 shipped (its kinda heavy for being this size)
Stock GM Z28 Oil Cooler Adapter and lines
This is from a Z28.
Asking $45 shipped
Thanks for looking
Potential Trades:
LS3 rockers
Tubular K member
Koni Yellows
Spark Plug Wires
350 Block
Here’s what I have:
Plenum – 14081006
Lower Intake
OR
(2) 10066015
Fuel Lines
OR
Fuel Injectors
ECM’s
Wiring Harness
SuperRam Gasket Kit
74196G – NIB
TPI Dual Fans
Asking $100 shipped
ARP intake bolts
Felpro Head Gaskets
TV Cable
Part #10163879
$25 shipped
TPI Throttle Cable
Part #10163822
$20 shipped
TPI EGR Valve
part #17085813
$30 shipped
Emissions Bracket
part #14073420
$25 shipped
Flexplate
$75 shipped
Water Pump Pulley
Part #10055880
$25 shipped
Jegs: $65.99
Sway Bars
This is from a Z28.
Asking $45 shipped
Thanks for looking
Car: 1967 c10 stepside short.
Engine: 350sbc L98intake Holley HP EFI
Re: TPI, TBI, Borla, Accel, FelPro, K&N, etc...
Whats the condision of the TPI throttle body, and price?
Car: 91 Z28
So you are looking for the things on the trade list? A bit confused..
Engine: 355
Here's some shots of the throttle body:
and this is what I WANT as far as trades are concerned:
LS3 rockers
Tubular K member
Koni Yellows
Let me know if I can get you more pics.
LS3 rockers
Tubular K member
Koni Yellows
I only need the throttle body. I need to know if there is play in the axle.
Car: 86 iroc,89iroc,98z28
Engine: 305,305,ls1
Transmission: 700r4/4l60e
Axle/Gears: 2.77/3.23
"Wiring Harness
I believe it’s a SD wiring harness, but I’ll need to double check on that".
how much and what year is it off
Car: 84 Camaro Z28
Engine: 355 Carb
do you have a pix of the borla is it.just the muffler
Car: 84 Camaro Z28
Engine: 355 Carb
evilstuie
01-09-2020 08:29 PM
ambainb
04-25-2016 09:21 PM
Sanjay
08-12-2015 03:41 PM
