[SC] T5 Transmission, CC Q-jet, Open Diff 3.23 Gears, 26 spline axles, instrument gauges
Car: 1986 Z28 Camaro
Engine: 350 with .440" lopey cam
Transmission: 6spd T56
Axle/Gears: Detroit Truetrac with 3.73 gears
I've got some extra parts from my 1986 Camaro up for sale:
T5 Transmission (non world-class) $250 OBO (SOLD)
Was working when I pulled it from my 86 camaro and upgraded to the T56. I'm not a mechanic though, it could have problems that I was not aware of. I do know the clutch was starting to slip a little when I pulled it though. I've got the clutch for it as well still if you want it though. I also have the torque arm and a oem style starter that will fit this if interested in those we can work something out. I do not currently have the cross member (although I might be able to get it, I left it at the shop and not sure if they threw it away yet or not, gonna go check this week), and the extra hydraulics I have atm are from a 4th gen since I used my 3rd gen hydraulics with a longer hydraulic line in the swap.
CC Quadrajet Carb $100 OBO (SOLD)
Again was working when I pulled it from my 86 camaro (305 engine). I upgraded the engine and went to non computer controlled equipment. Definitely needs to be cleaned as it has been sitting for a while.
Open Differential and 3.23 Stock Ring and Pinion $100 OBO (SOLD)
10 Bolt 7.5" compatible, series 3 carrier, for 26 spline axles. Teeth appear to be in good condition.
26 Spline Axles $50 OBO (for 2 of them)
For a hub brake. I don't have a picture of these right this second, but the teeth on the appear to be ok as well. There is the normal rubbing spot where the bearing sits.
Stock Aluminum intake $50 OBO
Stock aluminum intake off a 305 from my 86 camaro. Spread bore pattern. Has EGR holes in it.
85 MPH Speedometer complete Instrument Cluster set $100 OBO SOLD
Pulled from the same 86 camaro during the transmission swap. All the gauges worked at the time. 30733 on the odometer. Includes clear plastic, and panel trim, but I do not have the green inserts for the turn signals.
Also just to note, I still have my Z28 Wheels and tires for sale. Never had anyone interested in buying them. See the old thread here: https://www.thirdgen.org/forums/exte...ls-almost.html
I will ship any of the items listed for actual shipping costs, although they'd probably be rather expensive for some of the items like the transmission. The differential and gears are also somewhat heavy so probably expensive to ship too.
Want a title? Post!
Car: 1989 Camaro Iroc Z
Engine: 5.7L 350 TPI
Transmission: Manual T-5
Re: T5 Transmission, CC Q-jet, Open Diff 3.23 Gears, 26 spline axles, instrument gaug
Hey I'm interested in the transmission and wondering if it's still for sale
The only things that have not been sold is the intake, the axles, and my z28 wheels / tires are still available. (Does no one like the z28 wheels or something? lol.. haven't had hardly any interest in them).
Ghettobird52
07-05-2024 11:18 PM
hectre13
08-26-2015 08:17 AM
red90IROCls1
08-25-2015 06:56 AM
