[TX] Milodon High Volume Water Pump - Serpentine
1 Post
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Hey all,
I just finished switching all of my brand new cooling system from my 350 Suburban to the 454, and the water pump does not interchange between the small block and big block. It's a Milodon High-Volume pump with only 12k miles on it. I installed it last summer to help keep the beast cool towing my boat and everything I owned down to Texas in the middle of August. It kept it below 165 degrees the entire way (at 70-75 mph in 100+ degree heat), and I had it weighed in at the truck stop at 11,000 lbs with the trailer.
In my opinion, its the best waterpump out there for the cost. I'm running one on my 454 too. The only other pump I trust is the Edelbrock 8881, which is what I have on my GTA. These are very sturdily built, and it made a big difference over stock in cooling. It runs $89 new from Summit http://www.summitracing.com/parts/MIL-16213/. I'm asking $45 plus the ride.
I installed it after doing a double system flush with Peak Radiator Flush. After the flush, I drained ALL coolant from the engine until it was running straight distilled water. I then added the proper amount of concentrated Peak Lifetime Antifreeze to bring it up to a 50/50 mixture over the complete system (complete capacity given by the factory service manual). I also added Water Wetter additive for the seals. The motor it was on only had 30k on it (the pump went on at the same time that I put the Vortec heads on, and it was clean as a whistle inside). There's still a huge amount of life in the pump, I'd say it's barely broke in.
I'll mark it as soon as it's sold.
-cal30sniper
In case you didn't click on the link, this is a reverse rotation water pump for an '88-up Serpentine Belt system small block.
-cal30sniper
1 Post
Engine: L98/454/M20
Re: Milodon High Volume Water Pump - Serpentine
Things that go bump in the night...
Summer's here. Somebody might really need this to help keep you cool through the heat.
-cal30sniper
-cal30sniper
1 Post
Engine: L98/454/M20
Bump again...
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
ill take that intake off your hands thats in the picture . bump for ya on the waterpump though
1 Post
Engine: L98/454/M20
Thanks for the bump! I'll get the intake listed eventually. Right now, it's only purpose is to keep the elements out of my engine. That's the 35k mile 350 Vortech motor out of my '90 Suburban. It's going on an engine stand for a year or two until I get the time to drop it underneath a high-flow TPI setup with a mild roller cam in the GTA.
Engine: L31 350
1 Post
Engine: L98/454/M20
Bump.
1 Post
Engine: L98/454/M20
Let me get a quote for you tomorrow and I'll shoot you a PM about it.
1 Post
Engine: L98/454/M20
Bump. MikesprojectZ quit responding, so it's still available.
1 Post
Engine: L98/454/M20
Bump, still have this thing.
evilstuie
01-09-2020 08:29 PM
ambainb
04-25-2016 09:21 PM
evilstuie
04-14-2016 08:52 PM
