[NH] XR-288HR10 (12-433-8) cam RETROFIT hyd roller
TGO Supporter/Moderator
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Like the title says, comp cams hydraulic roller XR-288HR10 camshaft. This is on a small (1.050") base circle for rod clearance. Like new, couple hours of run time. I'd like to get $200 plus actual shipping or best offer. These are over $300 new.
Camshaft Part # 12-433-8 Grind # XR288HR-10
Duration @ 0.006": 288° / 294° Duration @ 0.050": 236° / 242°
Max Lift w/ 1.5RR: .520" / .540" Lobe Separation: 110°
Lobe ID#'s: 3316 / 3317 Intake Centerline: 106°
-- Joe
-- Joe
1 Post
Car: 92 Camaro Z
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
Re: XR-288HR10 (12-433-8) cam RETROFIT hyd roller
-- Joe
-- Joe
How would this cam perform matched up with a set of vortec heads?
The 10 degree split wouldn't be bad on vortecs, a guy on another forum dyno'd at 458hp with the xr288hr and vortec heads on a 10.5:1 engine.
Are YOUR vortec heads set up to handle that much lift? He's running 986-16 springs.
Also it's a retrofit roller cam for older (pre 86) blocks, not an OE roller cam.
-- Joe
TTT once more, then it goes on ebay.
-- Joe
-- Joe
1 Post
Car: 92 Camaro Z
-- Joe
-- Joe
This cam is SOLD. Thanks!
