[NY] SC53 VSS (speed sensor)units on Ebay $25
FYI Only
This guy is selling the police style dual output VSS sensors for $25 plus shipping. These are the units with both manual speedo cable and electronic VSS sensor plug.
http://www.ebay.com/itm/VEHICLE-SPEE...59150143012082
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Re: SC53 VSS (speed sensor)units on Ebay $25
What does it do exactly?
Can it convert electronic trans speed output to run a cable speedo?
Check out this one..you can see both plugs on the sensor. (ie you can run a cable speedo and have the 4 pulse signal at the same time for your TPI)
http://www.ebay.com/itm/140664505723...=p5197.c0.m619
Read this post to determine which sensor (black or white) you need according to sensor drive gear teeth.
https://www.thirdgen.org/forums/tran...-vss-help.html
Car: '85 Camaro
So is this whats needed for my '85 cable driven speedometer to work with my t56? Where would it hook up at?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
as well as get the VSS signal required by the ECM
Car: '85 Camaro
Hmm...interesting. I'll have to check it out and see what the ls computer is. But I thought any tuner and program what pulse signal you want?
I definitely need one though, kinda sucks not having a working speedo lol.
HEY FOLKS THEY'RE DOWN TO (FOUR DOLLARS) $4 EACH RIGHT NOW!
Here is the link again...
http://www.ebay.com/itm/140487876207...84.m1439.l2649
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Will this work for my TPI with T56? So I don't have to buy that stupid converter?
1 Post
Car: 82,83,99 T/As
Engine: 350,350,383
I get it. It can turn a cable driven speedo AND an electric speedo.
Does this make sense:
If you swapped an LS1+T56 into your car, you would pop this into your T56. The stock cable driven speedo can still be used because this has the provision. You can hook the stock T56 speed sensor connector into this also to signal to the ECU. If it is at 4000 pulses, you should be able to just tune the ECU out like you would when you change rear gears.
Is the above correct? If so, that's very useful...
ambainb
04-25-2016 09:21 PM
1992 Trans Am
08-08-2015 08:16 PM
