[IL] Machined 350 block (880 casting)
1 Post
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
This block is a fresh 40 over, and is ready for assembly for a nice stroker kit. Cam bearings and all the fine work is already done. Outside of clearancing for a stroker, you're ready to bolt in and go. I bought this block from a friend to do a stroker out of it, but my directions have changed and I'd rather see someone else use it instead of watching it sit. It's been sitting in a climate controlled garage on a cloth tarp (the kind you use for oil spills and such), as well as being greased/covered to prevent any potential rust issues. All the block work was done about 2 months ago.
Asking price? $450
Trades? I need a set of 275/40/17 tires. That's about all I'm looking for right now.
I'm located 30 minutes from St.Louis on the Illinois side. I'll get pictures up as soon as I can.
Asking price? $450
1 Post
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: Machined 350 block (880 casting)
bump.. still got it. Went on vacation and forgot to get pictures. I should probably do that now I guess, heh.
gixxer92
09-01-2015 04:32 PM
Eric-86sc
08-24-2015 09:01 PM
