[IL] Built TH350 trans, BFG Drag Radials, Various Other Parts
Built turbo 350 transmission up for sale. Features coan internals, HD hardened sprag, and a auto/manual valve body. Filter and pan gasket are brand new and it also includes a chrome dipstick not pictured. Coan says it's good to 600+ horsepower. Only 2,000 street miles on it, nearly new. $650 takes it.
Shipping is not a problem.
Holley 770 street avenger carb, manual choke, New in box $350
New items:
Pair of craftsman flare wrench holders, $15 for the pair
TH400 kickdown switch with bracket, $30
Craftsman beam type torque wrench, $15
New items:
Re: Built TH350 trans, BFG Drag Radials, Various Other Parts
ATI billet timing pointer for SBC. Has a small cut in the back though doesn't affect performance and not visible when installed, $20
NOS nitrous super powershot/cheater plate for spreadbore/q-jet. New, never used $100
Huge trans cooler, almost a foot tall and over a foot wide, $30
Now for the pile of parts:
1" 4-hole carb spacer, $10
Chrome alternator bracket, $10
MSD pro billet distributor wire holder cap, $5
Chrome timing tab with adjustable pointer for small block, $5
Points/dwell/tach meter tool, $10
Staggered mount starter, Used once, $30
Sears power drill, $25
Standard 3 wire alternator, worked when pulled, $10
Master heat gun, $80
Comp cams adjustable pushrod length checker for small block, new in package $10 Sold
0-8,000 RPM with adjustable shift point arm tachometer, unknown brand $10
1 cowl vent for non-a/c, $20
Set of ARP main studs to covert to use of a windage tray, SBC, $30 - Sold
Not sure of the exact name for it, but the piece that screws into the back of the quadrajet carburetors with the vacuum piece for the brake booster and other vacuum accessories, $20
Pair of new starter bolts, $5
5 piece gauge ring set for 2nd gen firebird $20
USA made craftsman 1/4" ratchet, $10
New autometer sport comp fuel level gauge, $30
Chrome thermostat housing, $5
A/C recharge vaccum pump and gauge line, $25 - Sold
Pair of new energy suspension poly swaybar bushings 7/8" $10
One unopened pack of operation desert storm trading cards, $3
Craftsman 1/2" to 3/8" adapter, $3
Pair of heavy duty rear axle u-bolts, $10
Pair of adjustable coil spring helpers to lower or raise, $5
New in package dewalt 4" knotted cup brush for angle grinders. This bad boy will annihilate any rust or other crap $20
K&N valve cover breather, $8
Set of 5 flex ratcheting wrenches, size 3/8" to 7/8", unknown brand, - Sold
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
how much for the tranny cooler and carb spacer sent to 58561
pm sent out about the tranny cooler and carb spacer
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
I'll take the arp studs if they are complete and for large journal. pm me price to 23320 along with paypal info.
What's the range on this pushrod length checker ?
Car: 1985 IROC
Engine: 305 for now
Transmission: 700-R4
Axle/Gears: 3.73 w/ auburn posi
Do you still have the tranny? If so does it have a converter with it? Im looking for a 3 speed tranny to replace my 700-R4.
Terrell351
06-13-2021 01:13 PM
colton_carlson
03-08-2019 12:21 PM
