[KY] parting 1989 trans am 12k invested new afr, comp cams,bbk
below are some pics and a list of each part for sale plus more!
only reason i have decided to part ways with it is because my dad bought me the car when i was 16, and he died in nov, it's hard to even look at now, too many bad memories.
also every single thing on this car worked perfectly when the original motor gave out in 2002. i mean everything worked perfect, headlight motors, hatch pull down motor, etc.
reasonable offers considered, but nothing rediculous! like 500 for the bottomend when i payed 2000 for all of it! if i say firm, that means i'm not budging so don't waste your time.
more pics found here-----> http://www.photobucket.com/badgtatransam
everything listed below is brand spanking new and most is in their original boxes! accuumulated over a 5yr period, and is ready to be assembled minus balancing and some gaskets here and there. any parts listed below used will be noted under used and how old they are.........
i have well over 12k invested. it's one of those things you just never get out what you put in deals. parts are listed below as well as pics and pics of the car above.
i prefer local pickup, i will ship, (but you will be paying for the shipping costs not me!) a reciept will also be included as well as your change in the event it wasn't as much to ship as originally quoted.
i ship ups only!
feel free to call me at 606-854-5132. ask for adam. again, serious offers only please!
i have bought and sold on thirdgen.org and have good feedback, you are welcome to search here for it, my username is "BADGTA" also the car is listed on several other sites so you better get what ya need as quick as you can! first one with the cash in hand for each part gets it! all sales are final, will be happy to show parts by appointment if you so desire to come here for pickup!
can also photograph certain parts as requested and only if you are serious in buying somthing, if not please don't waste my time or yours!
engine:
they are all brand spanking new! never even balanced or assembled! only removed from boxes to photograph!
prices listed below are for seperated groups of parts. each item etc are grouped and will not be sold individually, too much shipping costs!
(this is how much summit wants and they don't even have the balancer or sfi flexplate) and forget about the bolts!
http://www.summitracing.com/parts/ESP-12101030/
asking 1000 firm for all the following
eagle 4340 forged crank
eagle 4340 forged h beams
probe 2256-f030 forged 2v flattops
king bimetal race bearings oversized for large journal radii
hastings moly rings
performance internal balance 6 1/4 balancer with timing marks
sfi flexplate
arp main bolts
arp balancer bolt
arp flexplate bolts
asking 500 firm for the following
compcams xfi 292 cam hyd roller
compcams pro magnum roller rockers, 1.52 ratios
trickflow 1 pc pushrods 7.300
new "genuine gm" roller lifters
compcams spider reatiners valvetrain
cloyes true roller timing chain, 3 way adjustable
timing cover
bolt on timing pointer
****500 firm for the following****
aftermarket ho distributor (small cap)
holley stealthram fi manifold port matched to 1205 gasket
bbk 58mm tb
30lb ford red top injectors
aeromotive mini adj race fuel pressure regulator
granatelli motorsports 255lph fuel pump
modified 90-92 sd harness coverted for 89 trans
old:
i would like to sell the rearend with the cobras below with the car, will part if offered good for them! make me a honest offer!
!!!!!!!!!!only 500 miles on the following below!!!!!!!!!!!!!!
gm 10 bolt disc brakes
3.73 richmond gears
timken bearings
slp posi unit
******sold items*****
9" moser group.......... sold
suspension setup...... sold
serpitine setup...... sold
oil pan group............. sold
scat racing seats....... sold
slicks and skinnys........sold
heads group...............sold
i ship ups only!
engine:
hastings moly rings
sfi flexplate
arp main bolts
arp balancer bolt
arp flexplate bolts
timing cover
bbk 58mm tb
old:
3.73 richmond gears
timken bearings
slp posi unit
Last edited by badgta; 02-02-2012 at 02:10 PM. Reason: edited to add new remove sold
Car: 1990 Firebird Formula
Engine: 350 TBI LT1 Cam 60cc Vortec Heads
Transmission: 5 speed
Axle/Gears: 3.08
Re: parting 1989 trans am 12k invested new afr, comp cams,bbk
125 firm for the following
brand new aftermarket aluminum water pump
used original complete serpintine system
smog delete pulley
105 amp acdelco alternator
powersteering pump and pulley
$125 for all? Would you consider $50 with the shipping for the used original serpintine brackets?
smog delete pulley
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
How much for just the hood? Would you consider shipping it? Nice car, btw. Thanks!
1 Post
Car: 1992 WS6 T/A
Engine: Turbo 383 with Holley Sniper
Transmission: factory 5 speed now Powerglide
Axle/Gears: Strange 12 bolt w/373 locker
What part of ky r u in? I may come take a look if its not too far away and its ok with u.
i live in harlan co, near the va border, i don't mind a bit if you come and look things over. phone number is 606-854-5132
thanks
oh, and no 2 the other 2 questions.
the serpitine setup was completely dissasembled, cleaned and repainted like new! plus they come with a oe type starter i fogot to mention!
the hood would cost a fortune to ship man, hence why i prefer a pickup deal for all of it, certain items i can ship, but nothing like that! ups would charge 200 to ship it and by the time it got to you more than likley it would be in a thousand pieces!
there aint no way you will find a better deal than what i got listed above. if you can you better go after it! im selling brand spanking new parts, i completely redone all the old ones like new also!
and i'm not into giving them away! firm means not negotible, other stuff maybe, ........
thanks
*****update*****
i will have new pics of parts for those you have pm'd about it and i will have price to your door costs pm'd to those who have asked for it! will be a few hours, please check back soon!
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
that's an awesome looking car right there! it's a pity is has to go my condolences.. but maybe your dad would be very proud of you building it the way you were planning it, when you're done?
anyways, interested in this stuff:
interested in prices for those single parts if you are willing to split them, but i'll take the serp drive and accessories for sure (but don't need the starter).
any specifics on the distributor, and the oil pan?
btw what color is your interior?
btw shipping to TX, don't worry
arp main bolts
arp balancer bolt
proform tall centerbolt valve covers
arp head bolts
timing cover
asking 100 obo for the following
kevco race oil pan
kevco oil pump pickup
melling m55a high pressure oil pump
smog delete pulley
arp balancer bolt
arp head bolts
timing cover
kevco race oil pan
smog delete pulley
Engine: LS1 / L03
alright, not a problem, that's what you stated anyways so what about those serp drive and accessories then? i could need the whole bunch.
shipping would be to Houston, TX 77054. let me know what you think. Thanks!
edit: also still seriously interested in these if you have some details about the oil pan.
Car: 1988 Firebird Formula WS6
Engine: LO3 305 tbi
Transmission: 700 R4
Axle/Gears: 3gen housing zexel torsen posi 3.42
I'm looking for the plastic trim that is aft of the headliner, grey. if you got it let me know how much you want.
the trim pieces will be the last to go, i want to try and sell the stuff above first. will write down requests for trim pieces and put them up and save them per request.
better hurry! i am selling stuff quick! just sold the rims and slicks i wanted for 600, and hesitance dying to buy the heads!
serpitine setup sold pending payment!
thanks again everyone for your condolances on my dad and your intrest in what i have for sale, god bless you all!
and thanks to bluegrassz for speaking on my trustworthyness.
love you bro!
love you bro!
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
That's and awesome looking car! It's a shame it is being parted out! I am very sorry for the loss of your dad. My condolences to you and your family.
*****update*****
new pics will be added momentarily of the seats, parts etc.
just sold the head kit i had grouped to the same guy who bought all the reace wheels/tires, he knew i had a smokin deal on this stuff.
everything thats still listed above is still available, i'll remove them and add them to the sold list once they are gone.....
better not wait either any longer everybody!!!, because it's gonna go away like all smoking hot deals do!!!!! get it now while you can before someone else buys it first with their tax check!
new pics as requested can be found below and at this link below
enjoy fellas!
enjoy fellas!
Car: 89 iroc convertable/ 84 z 12 sec
Engine: stock 305 tpi/ 383
is rear sold
Car: 1989 gta
Engine: 5.7 ltr
Axle/Gears: 9 bolt 3.27 limited slip
that is a beautiful car man! I am sorry about your dad as well I know how it feels.
well if i dont sell the 10 bolt with the car as a rolling chassis, i will gut it and part every single part left including the rearend.
but shipping it would be prohibitily expensive. id say in the 200 buck range just to ship, but if i do and you need it bad enough to pay for that much shipping, i'd take 200 for the rearend itself + whatevet shipping is.
yes the moser 9" is still forsale, thats a 3200 dollar+ rearend.
anything that gets sold will be at the bottom of the first thread.
and attention everyone, i (AM NOT) breaking the parts listed thus far above up! not yet anyway.
and again, you better get what you can before someone whos just cashed their tax check does! once there gone their gone!
Car: 87 GTA
Axle/Gears: 3.42 posi
I would be interested to she what shipping costs to 37331 although driving is not that far out of reach, is it the rearend that came from the car factory or do you know if its 28 spline axles or not? thanks
more than you want to pay i would say. the 10 bolt has 28 spline axles, slp takeout diff posi type wormgears, 3.73 richmond gears and its been modified for 9 bolt calipers thats on it.
again if i can sell it as a rolling chassis, the car, ra II hood, cobra r rims tires, ascd turbo wing 2 all for 1000, i will do that first.
if not i will consider yanking the rearend out.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Price for the Holley Stealth ram package to 06437?
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Keep the car man! I went through the same thing... My dad built the car, then I bought it off him when I turned 16... I put a ton of work into it, built a new engine and everything. Since I have owned it, the paint has gone to ****, tranny is currently bad, needs a new rear.
Just sit on the car for a while. I just don't want you to regret parting it out. It will get easier. I lost my dad last Feb.
id say 50-100 to ship, what i do is i get a envolope and put the shipping reciept and your change in it, then put it with your parts.
that way theres no hangups at ups and you just pay what it costs to ship. just say it will be a hundred, and i will send you back your change with the parts.
i can be trusted, hell 20 bucks is alot of money these days! i won't do any of my thirdgen bros wrong. not for anything! check my feedback!
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
PM sent, I have done business with Adam in the past. No worries.
the sportlines go with the other suspension stuff in a group. but if you and everyone else here read it more carefully, you would understand that.
the suspinsion group is either going to sanjay if 88roc1le decides he dosent want it.
don't worry, your only the 50th person in the past 2 days that have took it upon theirselves to try and regroup my stuff.
next one that does it is getting a mouthfull!
Supposedly sanjay posted a couple hours after 881le. I posted the day before. I'm not trying to "regroup" your stuff. I'm merely trying to give you my hard earned money for your stuff. But whatever, I dont give a **** about you, your riced out gta, or your sob story. GOOD DAY, quitter.
#42
Engine: 355 TPI
I think im going to have to back out unfortnately. I really would like to grab that intake and everything included from you but my daily driver needs to go into the shop for wheel bearings ( i dont have a press or time to do it myself) so thats going to eat some spending money for this week. I guess let it go to the next interested party.
As others have said too...im sorry for your loss.
#43
people like you make me sick about places like this, when you don't hear what you want or get what you want, you want to be a cry baby and call names and ****.
as for my "riced out gta" it's going to end up bringing more money than you could ever sell your pos running! so don't even go there!
and yes, i said first come first serve, 88roc1le pm'd me 2 hours before sanjay for the "SUSPENSION GROUP" you wanted just the spring, and i'm not busting stuff up like thjat, i'm already giving smoking deals on this stuff,
if you don't believe me, call summit or jegs and price all of it out!
and as for my sob story, remember punk, i don't have to sell a ****in thing pal! but i feel for you when the day comes you have to go through what i have with memories etc. people like you are low life scum. good rittance!
#45
****notice****
the interior parts and i mean anything interior will not be sold until all the above is sold, i want to sell the following as a rolling chassis. i will start a new thread in the interior forum for that stuff if i cannot sell the car as a whole.
i am asking 1000 for the car , i have 1000 just in rims tires alone! it comes with the (following only)
1989 pontiac trans am
ascd turbo wing II
gt auto ram air 2 hood
new coolant tank
new windsheild tank
cobra r polished 17x9 rims 500 miles only
bf goodrich ta kdws tires on rims above 500 miles only
10 bolt with richmond 3.73s and slp posi diff 500 miles only
classic industries complete console
factory seats gary
new headliner, sail panels and visors
good dash
leather t-top bag excellent condition
autogauge tach thats almost brand new
pioneer supertuner 3 cd player
ascd turbo wing II
new coolant tank
new windsheild tank
factory seats gary
good dash
#46
WOW..sombody needs momy to wipe his tushy for Him
makes ya. wana run out.and Give him. the good deal of the day..dont it
#48
****bump for price drop****
2000 takes all the rearend stuff,
remember its all brandnew never user moser 9" stuff
1000 for the rotating assembly! thats cast kit prices!
150 firm + shipping for taillights!
#50
****update****
i have had alot of requests etc for all the other stuff, interior etc, i have decided to part those items out instead of doing a rolling chasis, please don not send payment, just send me your name and what you want in a pm and it will be held for when i start parting it in a few weeks.
thanks
adam
thanks
adam
