Dual Fans (1988 TPI) low price, and more, low prices.
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Photos added! More items for sale!
-2x Factory Fan from a 1988 Trans Am GTA, DUAL FAN HARNESS NOW INCLUDED.$45
-Firebird Center Caps, good shape. $20
-Factory Firebird Intake (Air Cannister, Cannister Cradle, Rubber Pieces. *Will include K&N Filter, great shape, just cleaned and oiled.$45
-Reman Front 1988 Calipers (painted Maroon), with Hawks Performance Ceramic Pads, Slotted Rotors, 1000 miles on setup. $165
-Comps Cam 1.5 Roller Rocker Polished Aluminum half set and Comp Cams 1.6 Roller Rockers Red Anodized Aluminum half set. (supposed to mix on motor to fine tune exhaust/intake lift). $65 SOLD
-Performance Store InHouse Brand Starter, Two bolt sets (168 tooth & 153 tooth), grinded to fit header collecter. works well. $50
-Lucas 24lb Injectors 8x. $40 SOLD
-Diacom Diagnostics GM Standard Software, Complete Set, Works, With software. $100
Pictures will be up soon.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Dual Fans (1988 TPI) low price, and more, low prices.
That diacom is old school , but nice if you want the plus program let me know
Fan nounts are being used.
MORE PARTS:
-K&N 3 1/2" Cone Filter w/ Plastic Adaptor (Remove factory intake box and bolt filter to rubber tubing via plastic adaptor, easy mod eliminates air box, adds a little performance as well as a slightly deeper tone.)(Cleaned and oiled.) $30
-Reman Cast Iron Water Pump, painted silver, new. $20
-Accel 8mm Plug Wires, for 8 cylinder, new. $10 SOLD
-1x Moates G1 Adaptor, minimum use, great shape. $20/unit
-SSBC Two Way Proportioning Valve, Adjustable, Black Anodized, New.$25
Car: 86 Camaro, IROC springs & bars
Engine: Mild 350,Q-jet,headers
Transmission: M-21, 12#flywheel
Axle/Gears: 98 7.5, 3.73 torsen.
I'll take the mini starter, PM being sent.
^ Shipped out last week.
Sanjay
08-12-2015 03:41 PM
