[MA] Lightweight Flywheel
14088647 N
15 lb NODULAR IRON FLYWHEEL
Lightweight factory crate, It is designed for externally balanced, ’87 and newer Chevy V8s (crate engine applications). This flywheel uses a 10 1/2" clutch. Its ring gear outside diameter is 12 3/4"
Flywheel has 153 tooth starter ring gear
Lightly used, Hers some pics:
Good condition. $90+ ship
Thank you
Thank you
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Re: Lightweight Flywheel
Hi is that the 3.00 inch bolt pattern that for 87 and later 305 engines? If so I will go $100 shipped to 98844....
monte87cortez
09-26-2015 08:10 PM
