[OH] Single Garrett 76mm Turbo setup built for thirdgen
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I started a single setup in my Iroc, but plans have changed.
I have a Garret 76mm Turbo, .96AR that is brand new. It has a T6 mount turbine inlet, 5" turbine outlet.
I have a 25"x12 intercooler and a 3" polished cold side piping kit.
I have modified some ebay headers for a thirdgen, the turbo sits in the stock battery location. All that is needed is a crossover pipe made from the driverside header.
You will need a wastegate and BOV for whatever size motor/boost level you decide on, and the oil lines.
I'm asking around $900obo. I'd be willing to trade on an EFI setup with harness, ECM for my 383. Also be willing to look at some trade on rims like BMW or corvette with tires as long as they'll bolt up to a thirdgen. I have this locally on Craigslist as well.
Car: 88 camaro, 87 TA
Engine: 454 stock, built 468 400hp+150 shot
Transmission: WC t5, m29 t56 spec stg3 clutch
Axle/Gears: 9 bolt 2.77, 9 bolt 3.70
Re: Single Garrett 76mm Turbo setup built for thirdgen
an you post more pics of the headers as well!
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Will you separate or are you looking to sell the kit?
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Here's some pic of the headers.
No, I'm not interested in splitting it up at this time. Sorry.
I understand.
If you find a buyer for the turbo and headers I would be interested in making an offer on some or all of the cold side.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Same price? What else might you need to trade? I have two superchargers and a larger intercooler and other stuff, if your interested
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Bump. New price. Looking to clear this stuff out of the garage before winter hits.
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
No thanks.
I've had alot of interest in the headers. I'd like to sell this complete as of now. I may sell just the headers if this doesn't sell later, and maybe do a rear mount setup if I can't move this.
FYI, the turbo was $980 back in the spring brand new so I'll find something to use it on before I take a huge loss.
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
What kind of power is this capable of making?
Car: 85 iroc-z28
Would it work on a 355 or is just not enough motor for this size turbo?
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
It depends how good the motor flows on the exhaust side, and how much boost you want to make.
pm me if you want to go into more info.
it will push most cars into the 9's is that better? lol
what did you wind up getting for it? I really want to put one on this cheaper engine, but I'll have to wait till next season lol
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I traded it for a Procharger setup. P600B.
Prtobably looking at selling it as well. lol
why not? I want a setup for up to 550hp or a 70 mm T03/T04 style turbo with a/r of .78-.96 then it should work well on this 305 TPI, I mean same thickness cylinder walls, rods, crank, intake, its just smaller pistons, just like a import, strap a turbo on run 12psi+ and put out 450+ easy on pumpgas.
I have an extra 9th injector, an extra windshield washer pump and bottle, I'm thinking running some 33% nitro, extra fuel, and I can "Technically" double my power, and its still easier running continous power, than a 100+ shot for one run, so I'm likely going to try it without worry of breaking stuff. Its a lot cheaper than spray, you can use it for a weekend or a day or as often as you want, just sayin "Ain't nothin beats a V8!"
Terrell351
06-13-2021 01:13 PM
Street Lethal
08-13-2015 08:28 PM
