[IN] SFI approved C.A.T Fluid Harmonic Damper SBC 2mo. old
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
I have a used 2mo old C.A.T fluid damper. 8" diameter for ab
c. Paid 149.99 for it. If you aren't familiar with the company check out their website they d o alot of sprint car stuff.
Willing to sale for 100 shipped
CAT fluid dampers are manufactured from forged 1025 low carbon steel housing and injected with high viscosity silicone fluid. A nylon ring and nylon position guides allow the steel inertia ring a rotation freely inside the housing. The steel inertia ring rotates harmonically with the engine and absorbs the torsion vibration from the rotating assembly at any frequency and RPM. It thus extends the life of crankshaft and bearing and allows the engine to produce more power and torque. All dampers are tested to 12,500 RPM for explosion proof in compliance with SFI 18.1 Specification
http://www.catpep.com
Call or text james
317-752-7406
Call or text james
317-752-7406
Re: SFI approved C.A.T Fluid Harmonic Damper SBC 2mo. old
Comes with keyway and crank bolt
80 shipped
darwinprice
17
10-11-2015 11:51 PM
HoosierinWA
10-07-2015 10:15 AM
