[WI] REDUCED! Complete 10 bolt posi Rear end 4.10 ratio
Car: 1989 Iroc
Engine: 383 TPI
Axle/Gears: Auburn Pro-Posi, 3:73's
Complete 10-bolt posi rear-end for a 82-92 IROC Camaro. Complete rear axle minus the brakes. It has an Auburn posi, with Richmond 4.10 gears. I had it behind my 383 with an automatic. The differential is solid and hooked up every time. It has about 8,000 miles on it. The pinion seeps a little oil but I have the new seal for it. The seal is included with the sale. There is a slight gear whine. This is typical of the 4.10 gears. It never bother me any because my exhaust rumble covered the sound. Just add calipers, mounting brackets are there. PBR brakes were on it. Asking $275. If the distance is reasonable, I'll meet half way if you want to pay for the fuel. Thanks!
UPDATE:
Now included are:
- 2 qts. of fresh gear oil
- 1 bottle of GM Limited Slip additive
UPDATE:
Now included are:
Car: 1989 Iroc
Engine: 383 TPI
Re: Complete 10 bolt posi Rear end 4.10 ratio
Milwaukee, WI
Car: 1989 Iroc
Engine: 383 TPI
Re: REDUCED! Complete 10 bolt posi Rear end 4.10 ratio
Bump.... price reduced.
Car: 1989 Iroc
Engine: 383 TPI
Sorry. Local sales only.
Car: 1989 Iroc
Engine: 383 TPI
UPDATE FOR SPRING:
Now included are:
Now included are:
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
1992 Trans Am
08-08-2015 08:16 PM
