58mm 1000CFM Throttle Body
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I picked this up a long time ago on ebay and never used it. The paint has been partly stripped off the intake pipe and needs a sand blasting or painting. The TB is in pieces but everything is there to put it back together except the IAC bottom plate.
Two of the screws are stripped that hold the blades, see picture 7
http://lukeskaff.com/sell/TB_1.JPG
http://lukeskaff.com/sell/TB_2.JPG
http://lukeskaff.com/sell/TB_3.JPG
http://lukeskaff.com/sell/TB_4.JPG
http://lukeskaff.com/sell/TB_5.JPG
http://lukeskaff.com/sell/TB_6.JPG
http://lukeskaff.com/sell/TB_7.JPG
Make me an offer
Make me an offer
Re: 58mm 1000CFM Throttle Body
Is it that one set of screw holes is stripped and the screws are broken off in the second set (that's kind of what it looks like in the picture but it's a bit hard to tell)?
Why was it taken apart in the first place? Are the throttle shaft holes worn out or something?
Do you know anything about it/who made it?
Car: 1989 Iroc-Z
Sorry I did not describe that very well, the two screws are broken off in the second set. They will need to be either drilled and tapped or drilled with a very small bit to use a reverse thread extractor tool.
The whole thing was painted bright purple, that is why I disassembled it to strip it down. I had a sand blaster at the time and was going to sandblast the intake pipe but never got around to it.
At this point I am just willing to sell it for cheap.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I'll take it off your hands !! that's really cheap ...
Terrell351
06-13-2021 02:13 PM
mdtoren
08-16-2015 06:45 PM
