BRAND NEW XR276HR-10 camshaft plus+
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Like the topic says I have a brand new XR276HR-10 cam for sale still in the original box from comp cams. Bought it for a vortec project I was working on but never ended up finishing. Purchased from summit I still have the receipts for everything lister. Asking 200 +shipping for the cam. I also have brand new summit lifters and spider retainer I purchase at he same time also still in their original boxes.
Link to the spider-
http://www.summitracing.com/parts/EDL-97386/?rtype=10
60 + shipping
Lifters-
http://www.summitracing.com/parts/SUM-HT214/
70+ shipping
Cam-
http://www.summitracing.com/parts/CCA-08-423-8/
Brand
COMP CamsManufacturer's Part Number
08-423-8Part Type
CamshaftsProduct Line
COMP Cams Xtreme Energy CamshaftsSummit Racing Part Number
CCA-08-423-8UPC
036584025030
Cam Style
Hydraulic roller tappetBasic Operating RPM Range
1,900-5,600Intake Duration at 050 inch Lift
224Exhaust Duration at 050 inch Lift
230Duration at 050 inch Lift
224 int./230 exh.Advertised Intake Duration
276Advertised Exhaust Duration
282Advertised Duration
276 int./282 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.502 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.510 in.Valve Lift with Factory Rocker Arm Ratio
0.502 int./0.510 exh.Lobe Separation (degrees)
110Computer-Controlled Compatible
NoGrind Number
CS XR276HR-10Valve Springs Required
YesQuantity
Sold individually.
Link to the spider-
60 + shipping
Lifters-
70+ shipping
Cam-
Brand
08-423-8Part Type
CCA-08-423-8UPC
036584025030
Cam Style
NoGrind Number
YesQuantity
Sold individually.
TMZIrocZ350
10-07-2015 12:09 PM
