[CA] FS: Edelbrock 6085 heads & air-gap manifold
Selling my set of Edelbrock centerbolt heads #60859. Had the motor and heads gone through and redone at a local machine shop and has been sitting waiting to go into the car. I recently purchased a set of Dart Pro 1 Platinum heads and EFI so it's time to put the Edelbrocks and Air-Gap manifold #2604 on the market. Heads have zero miles on them since they have been gone through and checked and are ready to bolt on and go. 3 angle valve job / resurfaced / vacuum tested / springs tested / everything good.
Manifold is brand new and has only been bolted on.
$800 for the pair of heads
$200 for the Manifold
Part numbers description as listed on Edelbrock site:
#60859 Performer For 1987-95 Centerbolt
Designed for 1987-95 Throttle Body Injected (T.B.I) and Tuned Port Injected (T.P.I) 5.7L S/B Chevy engines originally equipped with centerbolt valve covers. Performer centerbolt cylinder heads are 50-state Street legal and accept factory centerbolt valve covers. The intake bolt pattern utilizes the 1987-95, 73° angle on the two center bolts. Will Maintain stock compression ratio when used with the recommended head gasket. Made in USA.
#2604 Performer Air-Gap features the air-gap design for the ultimate street performance in the idle to 5500 rpm range. This design features an open air space that separates the runners from the hot engine oil resulting in a cooler, denser charge for more power. High-velocity runners deliver excellent throttle response throughout the power band. The great looks of the Performer Air-Gap along with the solid idle to 5500 rpm performance makes this an ideal choice for street rods and street machines. Performer Air-Gap #2604 is for 1987-95 cast iron heads with canted center bolt holes. No provision for exhaust heated chokes or exhaust crossover. Fits spread-bore or square-bore carburetors. Will not fit under stock Corvette hood.
I currently only have one picture, motor is at the shop so if there is interested I can get more pics.
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: FS: Edelbrock 6085 heads & air-gap manifold
I seen these on craigslist. I bought some a few months ago. otherwise you might have been getting a call from me. good luck on the sale.
86IROC112
08-17-2015 02:00 PM
