[MD] New In Box Eaton Posi Limited Slip Differential Chevy Gm 7.5" 28 Spl # 19599-010
Want a title? Post!
Car: 94 Camaro Z28
Engine: LT1 5.7 350
Transmission: 4l60e
Axle/Gears: 3.90
New in box is a Eaton posi limited slip differential for a 7.5 28 spline rear end. All the original paperwork is included as well. Big torque doesn't have to mean big traction problems. Eaton Posi Performance differentials combine carbon friction discs with precision-forged gears to give you great traction, even under higher torque loads. Plus, the carbon friction discs produce smooth, quiet performance for the life of your vehicle. If you are interested or have any questions please message me. I'm also located in Southern Maryland in case you want to meet up.
* Eaton Posi Limited Slip
* GM 7.5in./7.6in. 10 Bolt
* Automatic Limited Slip
* Carbon Fiber Clutches
* Forged Gears
* Rebuildable
* For Use With 28 Spline Axles
* For Use With 3.23 And Up Gears
* Part Number 19599-010
The price is $400
* Forged Gears
* Rebuildable
The price is $400
Car: camaro
Engine: 3.1 :(
Axle/Gears: stock
Re: New In Box Eaton Posi Limited Slip Differential Chevy Gm 7.5" 28 Spl # 19599-010
item kosts 455 on rockauto
EATON Part # EAT1959975 28 Spline; Ring Gear Diam: 7.5; 10 Cover Bolts; 10 Ring Gear Bolts Start Ratio 3.23; End Ratio 8; C-Clip Float (Only 1 Remaining)
1992 Trans Am
05-10-2023 07:19 PM
novaderrik
08-10-2015 12:44 PM
