[KS] interior A/C assembly- complete
interior side, complete A/C assembly
plastic 700r4 inspection plate
complete door ding moldings pending
tpi harness speed density sold
serpentine complete system scrapped
short block scrapped
4l60e torque converter scrapped
700r4 flex plate scrapped
heads-complete sold
CSR starter sold
730 ECM sold
burnable chip and Moates chip adapter with AUJP memcal sold
Milodon oil pan $40 sold
stock alternator sold
Holley Stealth Ram sold
700r4 w/ stall sold
MSD box sold
Hooker Headers sold
crank pulley sold
BBK 58mm throttle body sold
motor mounts scrapped
nitrous kit, plate wet system, w purge,lines, bottle sold
local pick up is fine and free. All parts best offer!!
Complete drivetrain, the engine is the original engine from the car it has been bored .030 has stock crank and rods with probe forged pistons flat top, Moly rings, rotating assembly has been balanced and blue printed, cylinder heads are iron l98s with 2.02 1.90 valves hand ported with Comp springs, keepers, locks and screw in studs/guide plates, cam is a gm 847 112 center duration @.050 is 234/242 Im not positive on the lift I think it was 540/560 on a with the 1.5 cat roller rockers, HSR, BBK 58mm throttle body, CSR starter,Hooker headers, Milodon oil pan, engine ran when pulled but will need rebuilt, it was pushing oil out dipstick tube.Trans works, 700r4. ecu with moates chip adapter, harness. Comes with all accessories exept smog, A/C compresser is there for belt routing but will not function (its been open for a year), have fuel rails and radiator hose neck, this is a complete drop out! Doing an LS1 swap. Located in Wichita KS. If there is no interest in the complete assembly then I will part out.
heads-complete sold
CSR starter sold
730 ECM sold
700r4 w/ stall sold
MSD box sold
Hooker Headers sold
crank pulley sold
Car: 1991 chevy rs camaro
Engine: 350 tpi 5.7
Axle/Gears: 373
Re: 91 350+700r4
whats a price on all of it cept 350? lol i got a 350 tpi in my 91 but i need to get the new computer, harness and trans (bro switched it all from a 91 rs to an 87 iroc z computer harness nd butchered it so i gotta get that fixed lol) and the trans well that was shitty i just had it rebuilt but its not working right. its got something to do with the linkage as it wont go into park and to get it to go into a gear u gotta pull it down to first for drive
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Re: 91 350+700r4
how much for 700r4 and willing to ship to 27531??
Re: 91 350+700r4
Can't you send a price for the hsr and bbk throttle body to dylan_jarvis2001@yahoo.com
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
Re: 91 350+700r4 part out HSR
what comes with the MSD box any wires?? Or is it just the box? if its everything complete ill take it.
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
You have doors listed in your ad! Were those the teal colored ones that were on craigslist? If not please elaborate.
1 Post
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
how much for the headers will they fit a 305 tbi ?
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Are the headers 2210s? If so very interested and consider them sold. Get me a price shipeed to 60632.
I dont know about the 305, they did come off of a 350.
PM sent
Yes, comes with the waterneck, fuel rails, fpr and AN fittings and hoses to connect into stock system.
Yes, they are the 2210s my set as you can tell by the picture are ugly but they are a great flowing header. PM sent
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Hey I could use the heads and short block complete, what would you want for that? private msg me and we can talk
what kind of heads were those again? So there was a gasket failure eh?
I'm very interested call me tomorrow
HSR will come with all sensors, fuel lines, all AN fittings, distributor, external coil, fpr, fuel rails, upper and lower plenum, fuel injectors, water neck,and all throttle brackets. To make it run you will need, all new gaskets, new plug wires, distributer will need rebuilt (cleaned, cap, rotor), fuel injectors will function but they are old and starting to crack at bottom and I recommend that you replace them.
msg me & we'll talk
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
would you sell the prom by itself and if so how much shipped to 66102
stock alternator $15 shipped
700r4 w/ stall sold- stall still available
Ecu 730 with chip and chip adapter $125 shipped
tpi harness $120 shipped
MSD box $25 shipped
Hooker Headers $75 + shipping
crank pulley sold
motor mounts $10 shipped
CSR starter $120 shipped
Milodon oil pan $50 shipped
Doors D-P $40 each + shipping
heads $200 shipped
short block $200 +shipping
nitrous kit, plate wet system, w purge,lines, bottle $300 shipped
stock water pump $15 shipped
Power steering pump $20 shipped
LS1 windage tray $30 shipped
local pick up is fine and free. All parts best offer.
Complete drivetrain, the engine is the original engine from the car it has been bored .030 has stock crank and rods with probe forged pistons flat top, Moly rings, rotating assembly has been balanced and blue printed, cylinder heads are iron l98s with 2.02 1.90 valves hand ported with Comp springs, keepers, locks and screw in studs/guide plates, cam is a gm 847 112 center duration @.050 is 234/242 Im not positive on the lift I think it was 540/560 on a with the 1.5 cat roller rockers, HSR, BBK 58mm throttle body, CSR starter,Hooker headers, Milodon oil pan, engine ran when pulled but will need rebuilt, it was pushing oil out dipstick tube.Trans works, 700r4. ecu with moates chip adapter-?, harness. Comes with all accessories exept smog, A/C compresser is there for belt routing but will not function (its been open for a year), have fuel rails and radiator hose neck, this is a complete drop out! Doing an LS1 swap. Located in Wichita KS. 1,000 OBO. If there is no interest in the complete assembly then I will part out.
MSD box $25 shipped
crank pulley sold
heads $200 shipped
Hey what size is that oil pan you have? I still am gonna need one of those for the motor I'm building
#42
Car: 91 Camaro Z28
Engine: 5.7L
Re: 91 350+700r4 part out Nitrous, TPI harness, more!
interested in the nitrous kit, plate wet system, w purge,lines, and bottle. can you sell for 200$ shipped to 35540.
#47
Car: 87 GTA
Axle/Gears: 3.42 posi
Re: 91 350 part out, Nitrous, TPI harness, 730 ECM more!
So you have the bottle and all? Is it ready to bolt on and go? Also, what are you asking for it?
