[Sold] complete tpi intake
Car: 85 Trans Am
Engine: 383 HSR
complete tpi intake
I just installed a holley stealth ram on my car and would like to sell my old tpi system. It has been slightly ported and polished, nothing too serious. The fuel rails have been polished to a mirror finish and the base, runners, and plenum have been painted black with some red added on the plenum. I am asking 250 plus shipping for everything.
sale includes:
plenum
runners
base
bbk afpr
polished fuel rails
rubber fuel lines
metal fuel lines
all sensors and vacum line nipples
water neck
new 19 lb injectors
feel free to ask any questions
SOLD
sale includes:
plenum
runners
base
bbk afpr
polished fuel rails
rubber fuel lines
metal fuel lines
water neck
new 19 lb injectors
SOLD
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: complete tpi intake
That came off a 305, correct? I ask based on the 19lb injectors.
Did that come off a perimeter bolt headed engine? Which would mean it would fit the older perimeter bolt valve cover heads?
I know it is not listed, but no throttle body? Did you reuse it on your 383?
Car: 85 Trans Am
Engine: 383 HSR
yes it came off a 1985 305 and yes the valve covers were perimeter bolt. The throttle body i had bored out to 52mm so i reused it on my 383.
Car: 85 Trans Am
Engine: 383 HSR
ill go ahead and through in the matching set of valve covers also if someone would like them
Car: 85 Trans Am
Engine: 383 HSR
took some close ups of the manifold ports and of the polished fuel rails. My car ran rich with that setup so the carbon buildup makes it hard to see any porting i did to it. Some paint thinner or just gas will clean it right up
Car: 85 Trans Am
Engine: 383 HSR
just so you guys can see the kind of porting i do i uploaded pics of my freshly ported HSR. It is nice and clean so you can see it clearly
1 Post
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
since the base is already to bolt to my world products s/r torquer heads i'm interested
Terrell351
06-13-2021 01:13 PM
1992rs/ss
05-19-2020 07:02 PM
Sanjay
08-12-2015 03:41 PM
