[MO] SBC Engine and Misc. SBC Parts
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
I'm in Saint Louis, Missouri.
First off is the engine. Probably needs rebuild. 200 bucks pickup only
I'm selling this because the crank is sliding back and forth about 1/8th of an inch which means its either a thrust bearing or crank journal is bad and I'm done with trying to fix this thing. 350 block, it has 305 heads on it (#601). New timing cover, new harmonic damper. The cylinder head with no paint on it is new, the one with the scratched orange paint is from my firebird with 160k miles on it still in usable shape. If you want more pictures of something just ask and I'll take it apart, I don't mind. Engine cradle is free with it.
Next is 2 carbs one is e4me one is m4me, both need rebuild (e4me also needs another airhorn) 10 bucks each + shipping:
350 intake and valve covers. one of the valve covers has a bend as you can see, I'll see if I can wack it into shape if not I'll just toss it. 10 bucks for intake 5 for valve cover + shipping:
Re: SBC Engine and Misc. SBC Parts
Last is a SBC distributor non computer controlled type. Works fine, makes good spark, new cap, rotor, 20 bucks + shipping
Also got 2 alternators (ribbed style and the one for the 2 power steering pumps, 350 heads (complete crap probably smogger heads), 2 starters (one is 153 tooth and one is for 168 tooth), what else....I think that's it. I'll post more If I forget something.
EDIT: oh, I got some spark plug wires for the SBC too. New summit racing kind, blue color.
If someone buys the engine whole I'll probably just throw all this other stuff in too if they want it..
Everything is sold as is.
Ask if you want more pictures.
Thanks for looking.
Thanks for looking.
Car: 88 IROC-Z
Transmission: 700R4-currently being mildly built
Axle/Gears: stock 2.73:( with limited slip
what would it take to fix the 350 and set it up to a TPI system?
Terrell351
06-13-2021 01:13 PM
