going engine swap, TPI parts for sale, LOTS OF PARTS ADDED
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
hit a major rock on the way home yesterday and killed my oil pan and killed my engine(block).. so im going engine swap.. so all my TPI stuff is for sale
1. gone
2.gone
3. Brand new NEVER USED A/C Delco AFS-74 heated 3 wire O2 sensor, with weather pack connecter and O2 connector installed already, as well as wires for power and ground. ready to run, $65 shipped.. see picture below
#4. gone
#5. gone
#6. gone
#7.gone
#8. gone
#9. gone
#10. gone
#11. gone
#12. TPI stock radiator, with upper and lower hoses. $40 + shipping
#13. Stock center bolt valve covers, black with bolts..SOLD
#14. Stock smog A.I.R. pump, with pulley and mounting bolts SOLD
#15. Roller block spyder, this is the metal thing that holds down the roller lifters. SOLD
#16. Hydrolic roller lifters 150k on them SOLD
#17. roller "dog bones" these hold the lifters in the valley from turning... SOLD
#18. AC pump. good condition, $40 + shipping
#19. Serpentine aluminum brackets.. they hold the PS pump and smog/AC,SOLD
#20. PS pump, doesnt leak, only leaked from the PS box... SOLD
#21. 1LE/B4C oil cooler, includes the oil filter adapter, hard metal lines and rubber lines.. $65+ shipping
#22. 081 TPI 305 heads,complete, has broken header stud in driver side.. should be abler to drill it out. SOLD
#23. Speed density intake boot (the one that goes from the throttle body to intake) $40 shipped
#24. upper and lower TPI air intake snorkle with new filters $45 + shipping
I get a good deal on shipping since i have a FedEx connection, I accept paypay.. send me a PM if you want anything.
1. gone
2.gone
#4. gone
#5. gone
#6. gone
#7.gone
#8. gone
#9. gone
#10. gone
#11. gone
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
Re: going engine swap, TPI parts for sale, performance parts
do u have any heads at all for a 5.7l i am building a motor finally and needs heads let me know 801-874-4961
Engine: 4.3 Turbo
Transmission: 4L60
i have the 081 58cc LB9 heads... im told wouldnt be good for 5.7 L98..
Engine: 5.0 tpi
Transmission: 5spd
yeah the motor i am getting is from a 90 corvette and it does not have heads and i really dont wanna use the heads from my current motor because it is a 5.0 motor
Engine: 4.3 Turbo
Transmission: 4L60
Heated O2 sensor still for sale... brand new never used... as you can see i have both weather pack connectors.. all you have to do is run a ground and power wire...
1 Post
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Whats shipping like to Ontario Canada L9h7A6 for the plenum?
Do you have the bracket for the MAP sensor as well?
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
May be interested in the coil. How long was it used? Whats the PN? And, you know if it'll fit a V6?
Car: 1989 Iroc Camaro
Engine: Stock 350 TPI
do you have the hard plastic line like 1/8 inch that runs from throttle body underneath the plenum to back of engine. if you do price shipped to sumner iowa 50674
Engine: 4.3 Turbo
Transmission: 4L60
Re: going engine swap, TPI parts for sale, LOTS OF PARTS ADDED
i know people need some of these parts
1 Post
Engine: L98 TPI 5.7L 350
Transmission: 700R4 Automatic
is any of ur egr stuff for sale? egr temp sensor? thanks.
Engine: 4.3 Turbo
Transmission: 4L60
I have all of it still, yes its for sale, i have the GM egr valve and vacuum solenoid, whats is the egr temp sensor??
1 Post
the egr temperature sensor is the little copper cylinder piece with a wire coming off the harness that screws in to the base of the egr under the plenum.
im looking for that plus an egr valve that has an "N " stamped on it. my old one had the gm part #17085813 followed by 82N (which is year and negative backpressure style. if so how much to ship both, ( dont need the solenoid anymore )to 92585. thanks.
Engine: 4.3 Turbo
Transmission: 4L60
theshackle
03-05-2017 06:37 PM
