[Sold] F/S Built posi disk rear 7.5 Eaton/Yukon
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
Hello up for sale is my rear end built 5 seasons ago . I t has a Eaton posi carrier , Yukon 373 gears ,Yukon 28 spline axles , all Timken bearings , LPW ultimate cover , UMI bolt on relocation brackets (that are welded in place with gussets) and it was cleaned primed painted before it was installed . I have put about 5000 miles on it with no issues . I have run 13.1 with this rear (about 15 passes) with a T-56 , 383 , MT Drag radials and a 32 LB centerforce flywheel . I have added about 150 horsepower to the car (motor not insalled yet )and do not want to grenade it . That is why I'm selling ,would have no fear running 12 flat with auto car 650 $ .
Car: 85 IROC Ht
Engine: 383 carb
Re: F/S Built posi disk rear 7.5 Eaton/Yukon
For serious interest i will remove cover and send photos of ring gear .650$
Car: 82 camaro
Engine: 383 strocker
Transmission: th350
no offense but u are asking way to much for that rear, people are getting into built 9 inch rears for that much. in the car game u never get back what u paid for an item when u sell it, especially after u raced on it. jmho drop the price and u will see alot more interest it looks like a nice rear for any street guy.
Car: 85 IROC Ht
Engine: 383 carb
I guess you did not read the post above that said OBO. The only thing you will get for 1000$ 9" will be the housing . I have close to 1500$ in parts alone in this without the rear . New calipers , rotors , pads and all the stuff above . The only thing used says , is that it is proven for 13 flat & 1.7 60' with Drag radials and a very heavy flywheel . Find me a complete 9" OR 12 bolt third gen rear with disc brakes and quality aftermarket parts for less then 2500$ and i will buy it .
Want a title? Post!
Car: 1986 IROC
Engine: 350 30 OVER 650 DP
Transmission: 700 R4
Axle/Gears: NEEDED
How much to ship to 01420.. Mass. If your in NY I might be able to come pick it up.. Also what is your lowest price?
hectre13
12-11-2023 08:14 AM
ambainb
04-25-2016 09:21 PM
hectre13
08-26-2015 08:17 AM
