Brand New Set of Trickflow Rocker Stud Girdles SBC
1 Post
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
Brand Trick Flow Specialties
Manufacturer's Part Number TFS-30400700
Part Type Rocker Arm Stud Girdles
Product Line Trick Flow® Rocker Stud Girdles for Chevy
Summit Racing Part Number TFS-30400700
Stud Girdle Attachment Style Clamp-on
Rocker Arm Nuts Included Yes
Rocker Arm Nut Thread Size 3/8-24 in.
Rocker Arm Nut Style Polylock
Minimum Rocker Slot Width (in) 0.600 in.
Tall-Style Valve Covers Required Yes
Stud Girdle Material Aluminum
Stud Girdle Finish Blue anodized
Quantity Sold as a kit.
Notes Designed for 23 degree Trick Flow heads.
These Trick Flow® rocker stud girdles for Chevy are CNC-machined and help control valve lift and timing changes due to stud flex, allowing for more consistent high-rpm performance. Each stud girdle is anodized blue and comes with high-quality mounting hardware and hardened adjusting nuts. Tall-style valve covers are required.
These are brand new in the box
$150
$150
Car: 86 iroc-z
Engine: 350 4-bolt
Axle/Gears: 4.10
Re: Brand New Set of Trickflow Rocker Stud Girdles SBC
do you think it will work with dart pro 1 heads?
1 Post
Car: 1987 IROC
I'm not sure. I would contact trickflow to be 100% sure
ambainb
04-25-2016 09:21 PM
LT1Formula
08-20-2015 09:36 PM
IrocZ'85
08-17-2015 06:24 PM
