Edgeracing 9.5" 3600 stall converter for 700r4!!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Here it is, a HARD hitting edgeracing torque converter for a 700r4, rated at 3600 stall. This converter is 9.5" in diameter and very light compared to 12" stockers, it has all the goodies including anti-ballooning plates for use with forced induction, heavy nitrous use(if your 700r4 can take it lol) and transbrakes etc. The hub shaft is chromoly and it employs dual bolt pattern on the mounting flange. Andre @ edgeracing warrantied this converter to 750hp, i was only making little over 420hp with my little 355 and this thing hits HARD!! it would flash to between 3600-3800 everytime! It was built with a 2.5 STR(stall torque ratio) so its nice and tight on the street and at the top of the track, best of both worlds. Only reason i'm parting with this converter is because i'm about to install a built th400 behind my turbo 400ci dart block motor, i decided to not even try the 700r4 behind that motor even though its built well. I paid $560+shipping for it.....i will let it go for $300 shipped to your door!!
Re: Edgeracing 9.5" 3600 stall converter for 700r4!!
SOLD!!!
Hotrodboba400
12-10-2019 07:07 PM
TheTraut88
09-07-2015 05:22 PM
