[PA] (3) Chevy High torque starters/70 Amp alternator
Just like title says I have the following for sale:
1) 70 amp GM alternator w/ v-belt pulley. Its not that old probably 1 year old or so. Basically has been off the car sitting hence the surface rust on the pulley. Just had it tested at the local Alt/stater repair shop. Works fine. $30
3) Chevy High torque starter for 168 tooth flywheel. Been sitting a while but wasn't used that long . Just had it tested at the same shop that tested the alternator. Works good $25
4) Chevy High torque starter for 168 tooth flywheel. Used a couple of years old. Works good $40
Located in Hatboro,Pa
db057
08-11-2015 10:11 PM
