[NC] Gen 1 SBC 383 All Forged and NEW
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I have decided to sell my 383 setup because I have my eye on something for the TA. All the parts are new except for the rocker girdles, heads, valve covers, and intake but are just as good as new. I won't separate any parts, its all or nothing so dont ask. I will not ship this stuff either, so its gonna have to be picked up. The heads are Cast Iron Sportsman II's that have been ported. They were like this when I bought them. I've had The springs installed and spring tension set, spring boxes cut,3 angle valve job, cleaned and resurfaced. They have 3/8 studs but come with the 7/16 studs as listed. I have about $1100 in these. They do have a little rust but have been in my storage building under a plastic bag.
The Victor Jr. is used but has been cleaned up a little on the inlet side.
Rings are Mahle 2m139 .040 .
The block is a 010 4 bolt main block with 1 sleeve. I bought it from the machine shop. I reccomend getting it decked since you can catch the sleeve with your fingernail. It had new cam bearings installed. It will need to be cleaned because of some surface rust. $450
I dont have any pushrods since you would need to measure once all parts are installed.
I also have a Pro Comp chrome electric water pump and a Pro Comp main girdle.
I have over $6000 in all this and I would like to start off at $5000 obo.
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: Gen 1 SBC 383 All Forged and NEW
ACL-5M909H STD - ACL High Performance Main Bearings $64.19
ACL-1B663h STD - ACL High performace Connecting Rod Bearings $65.92
ARP 134-3601 - ARP High Performance Series Cylinder Head Bolt Kits $73.48
ARP 134-5601 - ARP Main Stud Kits $78.16
ARP 134-7103 - ARP High Performance Series Rocker Arm Studs Kit $42.65
ARP 200-2902 - ARP Pro Series Flexplate Bolt Kits $13.95
ARP 230-7001 - ARP Oil Pump Stud Kits $5.95
ARP 230-7301 - ARP Torque Converter Bolts $14.95
ARP 234-1001 - ARP Cam Bolt Kits $6.95
ARP 234-2502 - ARP Balancer Bolt Kits $26.95
ARP 430-3503 - ARP Starter Bolt Kits $12.95
ARP 534-9601 - ARP Engine Bolt Kits $120.95
CCA- 12-772-8 - COMP Cams Xtreme Energy Camshafts $288.95
CCA-202 - COMP Cams Cam Buttons $5.25
CCA-2100 - COMP Cams Magnum Double Roller Timing Set $26.95
CCA 4004 - COMP Cams Stud Girdles $217.95
CCA 4605 - COMP Cams Cam Lock Plates $2.50
CCA- 977-16 - COMP Cams Valve Springs $125.95
CCA 818-16 - COMP Cams Endure-X Roller Lifters $386.95
CHM-28422 Alum Timing Cover $40
EDL-2975 - Edelbrock Victor Jr. Intake Manifolds $215.95
EMP-300 - EMP Stewart High Performance Thermostats $14.88
ESP-435037505700 - Eagle Forged 4340 Steel Crankshafts $546.95
ESP-5700B3D - Eagle ESP H-Beam Connecting Rods $373.95
FEL-1003 - Fel-Pro Performance Head Gaskets $35.95x2
FHR-9914-8 Keith Black FT4V Forged pistons
MEL-M55HV - Melling High-Volume Oil Pumps $32.95
MIL-40100 - Milodon Crushproof Premium Pan Gaskets $14.95
MOR-20191 - Moroso Street/Strip Oil Pans $209.95
MOR-24350 - Moroso Oil Pump Pickups $41.95
GM Performance 12363128 - GM Performance High Torque Mini Starters $249.95
Gm Performance 12361322- Gm Performance Aluminum Roller Rocker Arm Kit $330.
GM Performance 12363970- GM Performance Polished Aluminum Die-Cast Valve Covers $149.60
Professional Products 80002 $69.95
SUM-G100SFI - Summit Racing Street & Strip® SFI-Approved Flexplate $52.95
SUM-G2301 - Summit Racing® Valve Cover Gaskets $11.95
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
I'm looking for roller lifter to go in my 400SBC, those look like they are the "retro-fit" type (with link bars), how much for just those lifters...
Car: 87 T/A
crap, I didn't see that they were solid lifters, nevermind, sorry...
Mickeyruder
09-02-2015 02:45 PM
LT1Formula
08-20-2015 09:36 PM
