[VT] Tuned port injection system
1 Post
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
a tuned port injection setup, with runners, base manifold, upper plenum, egr, fuel rails assembly, thermostat housing, throttle body, all sensors except cold start switch.
Also, an ecm that needs prom. these are 19lb injectors, I ran them on a 350 with out problems. Base manifold has had a little porting. I got another setup that I am using instead.
Looking for $200. Would prefer a pickup, and not shipping. You can message me for more info. Ill try to get some pics up
9192camaro
16
02-03-2019 12:21 AM
Fast355
12-02-2016 06:33 PM
