Transmission temperature gauge, manifold, and transmission cooler
PLEASE READ THE ENTIRE AD! THANK YOU!
Trans temp gauge
pn: ATM4457
Gauge is missing the lightbulb that came with it. They can be had from Autometer for less than $5 i believe. Definitely less than $10.
Trans Temp Sender Manifold.
pn: ATM2286
The sender unit from the gauge is still screwed into the manifold.
Transmission Cooler
pn: TCI823800
Trans cooler from TCI
I can sell all three as a set, or individually. None of them were ever used!!! I never finished the project car. I ziptied the trans cooler into place and put the hoses on, but no fluid ever went through any of these peices.
Gauge was $62 brand new.
Ill sell it for $30 plus shipping
Manifold was $40 brand new
Ill sell it for $20 plus shipping.
Cooler was $80 new
Ill sell it for $50 plus shipping.
I would rather sell them all together!!
$100 all together plus shipping
Saves you $78-shipping(around 15 bucks probably)
I am located just outside Wash DC and have a couple other parts for sale. Search under my threads started.
Please EMAIL with any questions!!!!! I rarely log on and will not respond to PMs for a long time, maybe after the parts are already sold.
j_sigmon@hotmail.com
Trans temp gauge
pn: ATM4457
pn: ATM2286
Transmission Cooler
pn: TCI823800
Cooler was $80 new
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Re: Transmission temperature gauge, manifold, and transmission cooler
If those are -6AN connections coming off that tranny cooler, I WANT IT.
they are rubber hose. cant remember what the fittings on the cooler are. I have adapters for this size hose to -6an if you would like them with the cooler, but braided hose is not recommended for transmission fluid iirc. also the gauge is for transmision temperature, in response to the pm. if you look at the picture, it says that on the gauge! it also says that in the ad title and in the ad itself!!! PLEASE READ THE ENTIRE AD!! AND EMAIL DO NOT PM. PLEASE AND THANK YOU!
ambainb
04-25-2016 09:21 PM
6an, autometer, body, cooler, cooling, gauge, manifo, manifold, oil, sender, tci823800, temerature, temp, temperature, trans, transmission, trnsmission
