[MI] LS Swap Turbo Hot parts
1 Post
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
Im thinking about selling my turbo hot parts that I built that fit a 3rd gen LS swap. This set up performed very well and put down the power in my sig on a stock 6.0 with a blower cam. Im only looking to sell because im going to be going with a bigger turbo and a different trans, so rather than modify these I would rather just start fresh. This is a direct bolt on for a LS T56 car, will work with another trans but the crossover would probably have to be modified. I would include the turbo manifold, crossover, and 3" downpipe. You would just need to find a factory manifold for the driver side since I will be keeping mine. The crossover is 2.5", the primary's are 1 3/4 and the log is 2.5" with a t4 flange also flanged for wastegate. All of the vbands are stainless dynatech brand. All of the parts were professionally ceramic coated before this season started, and its holding up pretty well except for the manifold that seemed to get a little chalky from all the heat. This needs to be used with an ac delete box as well. I would like $800 for the hot parts. I also have the turbonetics 76mm turbo that I will sell for $500. The pic of the manifold was right when I got it back from the coater. Heres a link to my build thread to see how everything fits. https://www.thirdgen.org/forums/ltx-...1-z-6-0-a.html
Car: IROC Z
Engine: 355 MINIram w/boost
Re: LS Swap Turbo Hot parts
Im interested, just starting the 6.0 assembly and gathering parts. im going to check out your build thread for more pics.
Terrell351
06-13-2021 01:13 PM
1992 Trans Am
08-08-2015 08:16 PM
